Speed bleeders - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 06-26-2013, 05:17 PM Thread Starter
Speed bleeders
Folks,
I have a set of stainless Galfer lines in my garage waiting to be installed on my Wee. I have the brake master banjo bleeder included.
Do I want speedbleeders for the install?
Evan Z
2007 DL650 Blue Non-ABS
Suzuki Handguards, Suzuki Gel Seat, Eastern Beaver Headlight Relay, SW-Motech Centerstand, Givi Engine Guards, Givi Monolock 47 Topcase w/optional brakelight, Cee Bailey Perfect Storm 27" windshield, D2moto bar end mirros, Michelin Anakee III tires
aequus is offline
post #2 of 2 Old 06-26-2013, 11:05 PM
Nah. You can bleed the calipers just by connecting a drain tube to the bleed nipples and let gravity push the air out. Bleeding the master cylinder is more tedious, but your banjo bleeder makes it easy. If you don't get the master cylinder bled hard, just strap down the brake lever overnight.
