A couple of easy PCIII questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-10-2007, 04:17 PM Thread Starter
What type of computer operating system does one need to do their mapping adjustments and download??
What type of file is the mapping program in? Is the mapping program something like Excel,where you can input data and then save?
I'm considering taking my Vee to a dyno mechanic that charges $200 to do a dyno test. Is it reasonable to expect that the dyno shop will give me some type of document/computer file showing the map that they programed into the bike?
Thanks
Missouri Man is offline
post #2 of 8 Old 05-10-2007, 04:36 PM
MonkeyGrass's Avatar
Send a message via AIM to MonkeyGrass Send a message via MSN to MonkeyGrass
1) Windows. Ideally, a Windows laptop. Otherwise, you'll either need to break down your computer and set it up in the garage, bring the bike into the house, or get a REALLY REALLY long USB cable.
2) The map files are in a .map format that the PCIII software uses. Basically, it's a spreadsheet. The PCIII comes with it's own software to hook into the unit and upload/download changes. You can change, save, modify any and all maps.
3) Yes, the shop will essentially build you a custom map for your bike. You can then go home, hook it up to your computer, and save it, back it up, share it, whatever you want in the PCIII software. You should also get a before and after dyno-graph with your torque and HP curves.
[SIGPIC][/SIGPIC][I][SIZE=1][SIZE=3][SIZE=3][B]
V-Strom - embarrassing squids since 2002.[/B][/SIZE][/SIZE]
[/SIZE][/I][FONT=Georgia]DL1000K2 #938
[SIZE=1][COLOR=Navy][B][SIZE=2]Blue, of course!!
[/SIZE][/B][/COLOR][/SIZE][/FONT][FONT=Book Antiqua][SIZE=2][I][B]
R.I.P Jason. You will be missed.[/B][/I][/SIZE][/FONT]
MonkeyGrass is offline
post #3 of 8 Old 05-10-2007, 06:52 PM Thread Starter
Thanks for the information
post #4 of 8 Old 05-10-2007, 07:48 PM
MightyShep
I found some 10' USB extension cables at Staples so I chained a couple together and they reach the garage. Easier and cheaper ( I can't believe I'm giving mullet advice) than a laptop.
Also you will be able to download whatever map is currently on your PCIII by using the "get map" button in the PCIII interface. Really easy.
post #5 of 8 Old 05-10-2007, 10:42 PM Thread Starter
I don't have a laptop but as luck would have it, I have a window right behind my desktop computer that would allow me to pull my bike up outside the window and use one of those 10' USB cables. There's nothing wrong with mullet advice. thanks
post #6 of 8 Old 05-11-2007, 10:41 AM
MightyShep
I've got 3 of them strung together to get to the garage and experience no data compromise.
post #7 of 8 Old 05-13-2007, 09:48 PM
cmosentine's Avatar
USB spec is 5 meters cable length between hub and device. This can be extended by adding additional powered hubs. But as you found out, Scotty probably designed the spec and there is a bit of conservatism in the mumbers.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #8 of 8 Old 05-13-2007, 10:36 PM
MightyShep
Yeah, I'm sure there is some signal degredation, but since I'm only sending a small txt file I haven't seen any issues. Works great!
