Secondaries Rehash. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-10-2007, 12:18 AM Thread Starter
pizzmor's Avatar
Secondaries Rehash.
Just wanted to put this out there. I did a few simple mods to my Vee, K&N air filter, JSD ignition advancer removed the stock muffler baffles. It was not until I removed the butterfly secondaries though that the real performance of this bike came to life. For such an easy thing to do it yields a lot of satisfaction. Kudos to all of you Strommers for the advice to do it. The acceleration now without the secondaries is amazing, she just pulls and pulls all the way through the rev range. Highly recommended. I also lowered the front suspension and cranked down the spring rate, as well as in the rear. The handling is much improved as well. Now if I can only stop the pre-tank slapper weaving at high speed. This bike is truly the one that can do it all.
The more people I meet, the more I like my dog.
2 hp Briggs and Stratton powered minibike
1974 Husqvarna 250WR
1981 Honda CB750
1984 Kawasaki KZ550 LTD
1984 Honds Interceptor 500
1984 Honda VFR 700
1997 Suzuki Bandit 1200
1999 BMW K1200LT
2006 Suzuki Boulevard M109R
2006 Suzuki DL1000 V-Strom
pizzmor is offline
post #2 of 12 Old 05-11-2007, 02:15 PM
WARainman's Avatar
+1
I removed mine last night and I am happy with the improvement. I would still like to re-map, as my Vee is still a little rough on the low end. But removing the 2nd-aries was a good move.
WARainman is offline
post #3 of 12 Old 05-11-2007, 02:33 PM
Dave1's Avatar
Send a message via Yahoo to Dave1
Can you guys direct me to any posts/webpages where I can understand what you're talking about and how I could do this myself?
Dave1 is offline
post #4 of 12 Old 05-11-2007, 03:16 PM Thread Starter
pizzmor's Avatar
Try running a search for "removing secondaries". There are numerous posts on the topic, which is why I called my post a rehash. Basically what you do is remove the tank. Take the top of the air box off. You will see the two air intake stacks, two black rubber stacks with round butterfly valves. There will be 2 sets of butterfly valves per stack. You want to remove the ones closest to you. Also, make sure you keep the butterfly closed when you remove the screws so they don't fall into the engine. Also the screws are brass and will not react to magnetic screw drivers to be careful there. I also punched 2 in inch diameter holes into the top of the air box cover to bring in more air. I think the improvement is amazing.
1981 Honda CB750
1984 Honda VFR 700
1999 BMW K1200LT
pizzmor is offline
post #5 of 12 Old 05-11-2007, 03:19 PM
Heavy's Avatar
Unaccustomed as I am, I'll take this opportunity to suggest you use the search function. You would likely find a number of hits there.....like more than 100.
DL1000K6
Heavy is offline
post #6 of 12 Old 05-11-2007, 09:19 PM
WARainman's Avatar
Originally Posted by WARainman View Post
+1
I just PM'ed you.
post #7 of 12 Old 05-11-2007, 09:28 PM
Wee_Willie's Avatar
That was very subtle and "PC" Heavy!!
No disclaimer needed
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #8 of 12 Old 05-11-2007, 09:38 PM
http://vstrom.info/faq/index.php?sid...=29&artlang=en
Also check out plugs and Using a Throttle Body/IAPS vacuum balancer on same sight.
I've done all three things and am very happy with the results
IslandStrom is offline
post #9 of 12 Old 05-12-2007, 02:41 AM
MonkeyGrass's Avatar
Send a message via AIM to MonkeyGrass Send a message via MSN to MonkeyGrass
Hmmm... I should probably take note of how he did that! :rolleyes:
Heavy and "PC" in the same post... who'da thunk it? :mrgreen: :twisted:
[SIGPIC][/SIGPIC][I][SIZE=1][SIZE=3][SIZE=3][B]
V-Strom - embarrassing squids since 2002.[/B][/SIZE][/SIZE]
[/SIZE][/I][FONT=Georgia]DL1000K2 #938
[SIZE=1][COLOR=Navy][B][SIZE=2]Blue, of course!!
[/SIZE][/B][/COLOR][/SIZE][/FONT][FONT=Book Antiqua][SIZE=2][I][B]
R.I.P Jason. You will be missed.[/B][/I][/SIZE][/FONT]
MonkeyGrass is offline
post #10 of 12 Old 05-12-2007, 08:36 AM
Heavy's Avatar
I saw the guy didn't have many posts so I went easy. I didn't want eveyone, including bobbyk, accusing me of attacking everyone.
Just so you don't think I'm losing my touch.
DL1000K6
Heavy is offline
