Is cable re-routing necessary . . . - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-09-2007, 09:57 PM Thread Starter
whistler's Avatar
Thumbs up Is cable re-routing necessary . . .
. . . upon installing these on a Wee? I've read the boldfaced disclaimer about midway down the page, but wanted to get your real-world perspectives.
Thanks for your time and patience.
2019 Yamaha Tracer 900 GT (Annabelle)
2013 Suzuki V-Strom DL650 (Juliette)
2013 Yamaha FJR 1300 (Rachel)
2008 Suzuki Bandit 1250S (Fiona)
2006 Honda VFR800 (Jenny)
2005 Suzuki V-Strom DL650 (Hannah)
2003 Honda Shadow Sabre VT1100 (Veronica)
whistler is offline
post #2 of 14 Old 05-09-2007, 10:26 PM
Bimjo's Avatar
I didn't need to reroute anything, but I did need to work a bit of slack in the wire bundles.
Other than that it was smooth sailing all the way.
Jim
Perpetual Inertia Machine
Bimjo is offline
post #3 of 14 Old 05-10-2007, 06:06 AM
ON abs models you have 1/3 in of slack on brake line.
absdl650 is offline
post #4 of 14 Old 05-10-2007, 07:44 AM Thread Starter
whistler's Avatar
Many thanks, Bimjo and ABS.
whistler is offline
post #5 of 14 Old 05-10-2007, 08:10 AM
tmcgee's Avatar
You might need to rotate the grips, etc. on the handlebars. That's what it took for me.
tmcgee is offline
post #6 of 14 Old 05-10-2007, 12:56 PM Thread Starter
whistler's Avatar
Appreciate the info, T.
whistler is offline
post #7 of 14 Old 05-12-2007, 01:22 PM
joe t's Avatar
saw the pic of hanna is that a stock wind shield ?
joe t is offline
post #8 of 14 Old 05-12-2007, 08:12 PM Thread Starter
whistler's Avatar
Yep, Joe, it's a stock shield chopped down 5" from the top, and a vent cut in the bottom (the vent could be more shallow, but it works well as deep as it is). Roughed up the inside surface with 100 grit paper, wiped it down, then sprayed 3 coats of flat black on the inside with 20 minutes between coats in direct sunlight.
Crude, but it works well enough for me.
edit: Oh yeah, the shield's in the top position.
whistler is offline
post #9 of 14 Old 05-13-2007, 07:58 AM
cmosentine's Avatar
So, did your install go smoothly?
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #10 of 14 Old 05-13-2007, 12:46 PM Thread Starter
whistler's Avatar
Haven't done it yet, Chris. Still kickin' it around in my head.
whistler is offline
