New oil cap farkle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-08-2007, 07:53 PM Thread Starter
cmosentine's Avatar
New oil cap farkle
When I was looking at buying my DL1000 I came across a replacement oil cap which was machined aluminum with a recessed hex key for turning the thing. The sales pitch was to make it a little harder for someone to "put" something into the engine oil.
Can someone point me to this? Can't seem to find it now on the web.
Thanks
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #2 of 12 Old 05-08-2007, 08:01 PM
K1W1's Avatar
It's a Touratech item. Check their web site and catalogue.
It uses a 7mm hex key which is a non standard size so if you loose the key supplied you could have difficulty getting a new key.
K1W1 is offline
post #3 of 12 Old 05-08-2007, 08:27 PM Thread Starter
cmosentine's Avatar
Smile
Thanks a bunch.
2008 HD FLSTF
post #4 of 12 Old 11-30-2007, 10:14 AM
longgreensilverado's Avatar
i bought it and you can get 7mm hex keys set up to use in a rachet. most auto parts stores have 7mm in a 3/8 socket. buy a 1/4 to 3/8 converter and use a 1/4 rachet when installing the plug. a 3/8 rachet will make it too tight and possibly strip the threads
longgreensilverado is offline
post #5 of 12 Old 11-30-2007, 10:30 AM
Bright Side's Avatar
Really
I am just wondering, over the last 40+ years I have been riding throughout the US and Canada, has anyone had someone put something in their oil hole in their bike???
I have ridden with a wide variety of riders, and none have ever related a story that someone has put something in their oil or crankcase.
Outside of aesthetics you are actually causing some problems with getting into your oil hole. A story in fact: a friend of mine had replaced his oil filler cap with a fancy one with a special key to open it. Well, preparing for an up coming ride Jim dropped his little special key down the oil fill hole and into the engine. He didn't make the trip and he had to have his BMW RT taken to the dealer and have the engine split to get the little special tool out. They found it next the the cam chain.
Well enough said.
Bright Side
Bright Side is offline
post #6 of 12 Old 11-30-2007, 11:26 AM
liljoec's Avatar
^ I'm with ya on this one Bright Side. I think it might look kinda trick, but would probably be annoying in the long run.
2007 DL650
liljoec is offline
post #7 of 12 Old 11-30-2007, 11:42 AM
Berserker's Avatar
The key to the cap...
is on my key ring, probably won't fall into the engine. The key is bigger than the opening.
[U][URL="http://moveyourmoney.info/"]Move Your Money[/URL]
[/U]
Berserker is offline
post #8 of 12 Old 11-30-2007, 01:12 PM
james1300's Avatar
Boy's and their toyz! Blling!Bling!
james1300 is offline
post #9 of 12 Old 11-30-2007, 02:34 PM
kenneth_moore's Avatar
Not unless we were formally engaged.
kenneth_moore is offline
post #10 of 12 Old 12-03-2007, 12:19 PM
Kawidad's Avatar
:mrgreen:
Kawidad
2007 DL1000K7
Kawidad is offline
