Givi Top Rack Instalation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-06-2007, 12:41 PM Thread Starter
Quebecois's Avatar
Question Givi Top Rack Instalation
I was about to install a givi top rack that i recently bought when i realized i have to take off the rubber mat on top of the factory rack. Is there a way to take this off without cutting the rubber "nipples" on the bottom side of the rack?
I'd like to preserve the thing if i could. It could be useful if I ever decide to sell the bike.
thanks
Quebecois
Blue DL650 K5
Quebecois is offline
post #2 of 5 Old 05-06-2007, 01:05 PM
mrltt's Avatar
I have the JWhitney knock off from eBay and installed without removing - I think the installation and brackets are the same... If you search the site for top case installations there's a lot of info/directions/photos posted here.
Blue DL1000K7
mrltt is offline
post #3 of 5 Old 05-06-2007, 01:06 PM
Heavy's Avatar
I sprayed diluted dish soap all over the place to wet things and, hopefully, give some lubrication. I also applied my pull as close to the nipples as possible. Worked well.
DL1000K6
Heavy is offline
post #4 of 5 Old 05-06-2007, 01:22 PM
It also helps to push with a dull pointed instument from the bottom. Push the outside of the mushroom into the stem area.
post #5 of 5 Old 05-06-2007, 01:24 PM Thread Starter
Quebecois's Avatar
Thanks guys!
Quebecois
Blue DL650 K5
