Heated Grip vs Rear Brake Light Connector - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-16-2013, 09:45 PM Thread Starter
Question Heated Grip vs Rear Brake Light Connector
I've got an '09 Wee (with ABS) and am looking into using a horn lead attached to the unused heated grip connector to get switched power to a DC power outlet I'm installing.
I know there are several posts here about locating the connector, and I thought I had found it, but now I'm thinking what I actually found was the rear brake light connector. I've attached two images showing it's location and the connector itself. Looks like the connector *could* accomodate up to 4 wires, although it just has two - Orange/Green and Black/White.
It had a black rubber cap on it, and it wasn't taped down to anything.
Thoughts? I'd ideally like to find the Heated Grip connection so I can use a horn lead to cheaply and non-permanently tap power.
CastleSeven is offline
post #2 of 3 Old 06-16-2013, 09:50 PM
That's a new one on me for a capped connector. The wire colors are right but the horn lead won't fit. The OEM heated grip connector is behind the radiator.
post #3 of 3 Old 06-16-2013, 11:36 PM Thread Starter
Thanks GW, I'll keep looking then.
Tags
electrical connector , heated grips
