Getting to the #$%& horn lead... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 05-04-2007, 07:14 PM Thread Starter
JPryce's Avatar
After a solid week of riding to work in 30-ish degree temps, I finally cracked and ordered a set of non-OEM grip heaters.
The dealer is an inconvenient 40 miles away (no lead in stock), so I was planning to snip off the factory plug and replace it with Honda OE-style bullet connectors.
The problem is that the lead on the bike is only about 2" long, so I can't get my hand AND any tool in there to work. Looking at it from the outside, it doesn't appear that removing anything short of the tank, airbox, etc. will make any room to work. I hate the idea of stripping the bike to get to one stupid wire. So may others have done this - any tips?
2012 Super Tenere
2006 CRF50 with big-boy mods. :biggrin:
1973 RD350
JPryce is offline
post #2 of 15 Old 05-04-2007, 07:45 PM
V-Tom's Avatar
It doesn't help much but why not do a nice enjoyable 40 mile run on the Strom and get the right part? I'd phone ahead to make sure the part is in stock. (My daily commute one way is about that distance.)
I found getting to the lead really hard. The only saving grace was that once I got my big hands in there the plug went "click" and everything worked. I have heard of suggestions of moving the rad ahead but didn't followup up on that.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #3 of 15 Old 05-04-2007, 07:51 PM
you might regret the bullet connectors. heating elements require a pretty beefy connection. bullets might get hot.
TouringDude is offline
post #4 of 15 Old 05-05-2007, 12:17 AM
Do you plan maintaining your own bike?
How many miles on your bike?
Do you plan on adding other electrical farkles in the future? such as radar, gps, tunes.....
The reason I ask is the factory plug is hot at all times which runs the risk of draining the battery if the grips are left on. Stripping the bike down really isn't a big deal as long as you do a few things like add vaccum hoses for TBS which will make life so much easier down the road. Adding a aux. fuse box, removing secondaires, adding Iridium plugs............
IslandStrom is offline
post #5 of 15 Old 05-05-2007, 01:03 AM
It's only on when the ignition is on.
post #6 of 15 Old 05-05-2007, 01:16 AM
Funny, my factory grips were on regardless. --------------------------------------------------------------------------------
This is the Suzuki Part No. 36852-06G00 for the plug which would plug into the factory connector.
post #7 of 15 Old 05-05-2007, 02:49 AM
Did you install them? If they were dealer installed, they could have been connected somewhere else by mistake. That is the correct part number. I had Hot Grips on that part on my '05 and they went off with the ignition.
post #8 of 15 Old 05-05-2007, 10:28 AM
Night_Wolf's Avatar
My dealer wired mine so they were always "hot" I wasn't impressed :rolleyes: and changed it myself
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #9 of 15 Old 05-05-2007, 11:25 AM
On my 04 wee they were dealer installed. The factory kits is plug and play so I can't see where else they would plug them in. I haven't installed heated grips on my 06 Vee yet. To bad, I had the bike apart acouple weeks back I could of put a test light to that plug to see for sure.
post #10 of 15 Old 05-05-2007, 12:46 PM
The tips from someone who did it in the dark on a cold November day:
1. Take out the lower bolt on the rad so it can swing forward.
2. The heater lead is bundled up with another harness. If you follow the wires up with your hand you can find where the other harness plugs into the plastic piece behind the rad. You can pop that connector out and you will have more wire to work with.
3. Now remove the electrical tape and extend the heater lead so you can plug into it.
It was a serious PITA but now I could do the whole operation in 15 mins or so.
DL650K5 (Silver)
aircav is offline
