Shifter from Tourtech - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 04-27-2007, 11:09 PM Thread Starter
tblaney's Avatar
Has anyone installed the shifter from tourtech? Does it fit properly? It looks alittle smaller than the OEM..
Comments????
[B][COLOR="Blue"]" The mountains are nice but they sure do block the view!"[/COLOR][/B]
tblaney is offline
post #2 of 17 Old 04-30-2007, 10:19 AM
Berserker's Avatar
Yep...
have one on mine. When you replace it you have to remove all the linkage that Suzuki uses and the new shifter bolts directly to the shift rod. About a 3 on the mechanic skill level.
[U][URL="http://moveyourmoney.info/"]Move Your Money[/URL]
[/U]
Berserker is offline
post #3 of 17 Old 05-01-2007, 01:47 PM Thread Starter
tblaney's Avatar
A three out of.........
tblaney is offline
post #4 of 17 Old 05-01-2007, 02:23 PM
Berserker's Avatar
Talking A 3 out of 10
10 being very difficult.
[/U]
post #5 of 17 Old 05-01-2007, 09:35 PM Thread Starter
tblaney's Avatar
Thanks so much! Do you have any pics???
tblaney is offline
post #6 of 17 Old 05-02-2007, 11:20 AM
I looked on site and it says only for the V not the Wee. Are we talking V here or does it fit the Wee? Mike in Fremont, ca.
"What can will go wrong".
07 V-Strom 650
03 Yamaha FJR 1300
Its loaded to the max.
FJR/V-strom trooper is offline
post #7 of 17 Old 05-02-2007, 11:48 AM
It's made for the Vee with installation including the linkage. It will work on the Wee if installed directly on the shifter shaft without the linkage. The shift pattern will be changed to one up and five down though.
post #8 of 17 Old 05-02-2007, 04:05 PM
AlaskaTroy's Avatar
Um.........went right on my Vee same as the Wee. No linkage required.
K5 DL1000"Skull Strom",ZUMO 550,Staintunes,Givi Bags,Givi Crash Bars,PCIII,PIAA Lights,MoTec Skid Plate,Centerstand,Tank Cover,Touratech Radiator Guard,Custom Shift Lever, "VStrom" Chain Guard,Bar Riser 1",AK Leather Sheepskin Seatcover on a Sargent & a sweet Elka Shock http://www.friendsoffoamy.com/videos...nt-episode-023
AlaskaTroy is offline
post #9 of 17 Old 05-02-2007, 08:09 PM
Sorry. That's right. The difference is the linkage configuration. Both lose the linkage but the Vee stays in the usual direction. The Wee reverses.
post #10 of 17 Old 05-07-2007, 09:36 AM Thread Starter
tblaney's Avatar
Pics
Does anyone have any pics of the installation??
tblaney is offline
