I have heated grips! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 04-24-2007, 03:58 PM Thread Starter
dcwn.45's Avatar
It worked! I just finished installing dual star grip heaters.I used the horn lead connector from Suzuki[which I was able to connect from the right side of the bike without removing anything]and I re-used the factory grips.The clutch side feels slightly fatter than the throttle side now,because I put the insulator heat shrink tube on first as recommended by dual star because I have pro-taper aluminum bars and he said they would dissipate the heat too fast and the clutch side would feel cold without it. I started the bike and let them warm up and they seem to heat evenly on both sides,I only ran it for a few minutes on hi but so far so good.
If anyone is nervous about doing this mod,or is thinking of paying big $ to have some fancy grips installed by a dealer,DONíT it is very easy to do yourself,just follow the instructions and take your time. The install took me bout 2 hours.
dcwn.45 is offline
post #2 of 24 Old 04-24-2007, 04:01 PM
Heavy's Avatar
Congrats on the successful install.
Now go fill out your profile so we know where you are and if the heated grips are justifiable. Also, add a sig line so we know what you ride.
DL1000K6
Heavy is offline
post #3 of 24 Old 04-24-2007, 04:54 PM Thread Starter
dcwn.45's Avatar
There,I hope living in Mn.and getting nearly 3000 miles on since last fall makes my bike worthy of heated grips.[I do feel pretty stupid for not putting them on months ago].
06 DL650,red,of course.
dcwn.45 is offline
post #4 of 24 Old 04-24-2007, 11:53 PM
Heavy,
The address is Minnesota - that should qualify for heated grips. I think Minnesota gets colder than most of Alaska (it is too close to the ocean) and it is about as close to Canada as you can get.
Heck, I have, and use, and need, heated grips here in SoCal because I am an old wimp that rides in the dark, early mornings every day.
2004 dl650-the urban warrior.
2007 R1200RT - the highway beast
tinman is offline
post #5 of 24 Old 04-25-2007, 07:44 AM
I have the same setup. I find that the clutch side doesn't warm up as well as the throttle. I have Renthal bars with the heat shrink tubing as well. I kinda like the fatter grip on the left side. I used to have a problem with the grip moving on the bare bar. I guess the Renthals are smaller diameter than the stock ones.
You said you used the horn lead. Is this is a plug you can buy that will fit into the heated grip connector on the bike? If so I wasn't aware of this. I went medieval with my hookup and spliced into the heated grip wires behind the connector.
DL650K5 (Silver)
aircav is offline
post #6 of 24 Old 04-25-2007, 08:51 AM
Heavy's Avatar
I'd say MN is heated grip territory. Now, SoCal?? That is a different story!
I wasn't giving the man (I assume the person posting is a man) grief, just suggesting he add some details to his profile so we know when he posts in the future. Should be part of the requirements to get a username here. IMHO.
DL1000K6
Heavy is offline
post #7 of 24 Old 04-25-2007, 11:51 AM
Heavy, have you noticed your profile. Ontario is a pretty big location to come from. Haven't picked on you for a while so today is the day. lol.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #8 of 24 Old 04-25-2007, 01:20 PM
Yes. The Suzuki part number is 36852-06G00
post #9 of 24 Old 04-25-2007, 04:19 PM
Heavy's Avatar
Funny you hit on that. I was meaning to be a little more specific with my description but didn't get around to it.
Why, maybe I'll do it right now....
DL1000K6
Heavy is offline
post #10 of 24 Old 04-25-2007, 07:27 PM
I wish I had known about that a week ago. Oh well, thanks for the info.
DL650K5 (Silver)
aircav is offline
