elevation question! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 04-13-2007, 11:14 PM Thread Starter
elevation question!
just move from TN to CA and the bike dos'nt feel right.
is the ecm can adjust him self to the elevation?
do i need to do any thing?
i also have a full system exhaust(leo vince) k&n air filter and i had the bike remap(no pc. it was remap through the ecm).
any idea?
thanks in advance rafi.
suzukiman is offline
post #2 of 22 Old 04-14-2007, 10:49 PM
docsporseen's Avatar
Send a message via Yahoo to docsporseen
Where in California? If you're up in the hills, your computer needs time to reset itself. I don't know enough about bikes to know for sure, but I know my car would reset itself if you pull the negative off the battery for a half hour or so.
At higher elevations, a flow-through exhaust can pull off quite a bit a bit of torque from the engine. A good filter doesn't make a difference. Remember, too - California gasoline has a different formulation to it so that could make it seem to run a little odd.
Good luck getting it registered in Cali without their emissions system being complete. Hope it's different with bikes than cars!
docsporseen is offline
post #3 of 22 Old 04-14-2007, 10:51 PM
Oops - didn't see the Sherman Oaks tag. It's most likely the difference in fuel. Sherman Oaks isn't high enough to worry about (I lived in Bridgeport at the Marine Corps Mountain Warfare Training Center for 4 years, which is at 6,765 feet elevation). You can still do the reset thing I mentioned to see if it helps.
post #4 of 22 Old 04-14-2007, 11:30 PM
Vinny's Avatar
I'm sorry
Your ecm just needs to relearn, or just disconnect the negative terminal of your battery for an hour or so and reconnect and ride.
Me - DL1000K7 Black
Wife - DL650K7 Grey :mrgreen:
Vinny is offline
post #5 of 22 Old 04-15-2007, 10:56 AM
Heavy's Avatar
You don't mention if you are riding a 1000 or a 650 or what year it is.
But, if I recall correctly, our EFI is an open loop system.
No learning possible as there is no feed-back loop.
Disconnecting your battery will only mean you have to reset your clock.
DL1000K6
Heavy is offline
post #6 of 22 Old 04-15-2007, 11:15 AM
The various sensors for the fuel injection system seem to cover air pressure difference pretty well. My old 650 ran just as well in the mountains as it did at lower elevations on a trip out west. A switch from 100% gasoline in TN to 90% gasoline 10% ethanol may be part of the problem.
post #7 of 22 Old 04-15-2007, 11:19 AM
Keith Falkner's Avatar
My 2006 DL650 can climb.
Last June I crested Berthold Pass at 11307 feet in Colorado, and the bike was perfectly happy. Later that month it crossed the Rocky Mountains three more times, and never had a problem.
I believe the fuel injection system adjusts itself to atmospheric conditions as necessary. I wish I could do that.
Keith
Keith Falkner is offline
post #8 of 22 Old 04-15-2007, 02:02 PM
You do adjust...eventually. Took me a few months, but I stopped trying to die every time I looked at a hill.
"When I want your opinion, I'll give it to you" Author unknown (But a complete bastard!)
Navy Hospital Corpsman 1st Class, stationed in Camp Pendleton. 2007 DL650, now belongs to State Farm after my wreck on 17 January 2009. Proud owner of about a pound of titanium and steel in my left knee after the accident.
post #9 of 22 Old 04-15-2007, 02:40 PM
S83
S83's Avatar
Takes a day or two to get over altitude sickness.... They probably have a pill for that.
"Loud Pipes Risk Rights"
2006 Red VStrom DL650
AMA Member
IBA Member
S83 is offline
post #10 of 22 Old 04-15-2007, 04:36 PM
A1A
Thumbs up
Bingo!!!
I agree with with greywolf.
Cheers!
Richard #3125
Blue 05 DL650
Yellow 04 SV650N Scantily Clad
A1A is offline
