SW-Motech crashbar install ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-13-2007, 09:07 AM Thread Starter
cmosentine's Avatar
Hi all: Just received my SW-Motech crashbars. Looked through the parts and "instructions". Looks straight forward enough except for these points:
What order should I remove/install bolts?
Is the "long" bolt supplied with the bars the same or better grade steel than the OEM part?
Do I need to support and engine when removing the "long" bolt? Will there be any shifting of parts when the bolts are removed?
Any other tips appreciated! Thanks, Chris.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #2 of 10 Old 04-13-2007, 09:49 AM
Order doesn't matter. You can take out every bolt at once if you want and the engine won't budge. The through bolt is contained by larger adjusters that hold the engine in place. Use a pipe on the wrench to loosen the nut if necessary but once the nut is off the bolt can be removed with two fingers. The new large bolt is just longer than the original, not stronger. Use the required amount of large washers to keep the guard from touching the frame at the large bolt attachment area. Blue loctite on fasteners is a good idea.
post #3 of 10 Old 04-13-2007, 10:41 AM Thread Starter
cmosentine's Avatar
Can you define "amount" and "large". Should I use stainless, or is mild steel OK? Have you had and dissimilar metal electrolysis take place?
Chris
2008 HD FLSTF
post #4 of 10 Old 04-13-2007, 11:26 AM
Tollster's Avatar
I have had some corossion on some of the bolting but seem to thing it may be contributued to humidity, road salt and the like. The frame on the strom is a floating ground, meaning it is not grounded therefore if you should do any electrical upgrades always ground to the battery or your fuse block.
Tollster is offline
post #5 of 10 Old 04-13-2007, 03:37 PM
Chris
Amount=0, 1, 2 or 3. Large means the washers that fit over the bolt that goes through the engine. They come with the kit. You don't have to buy them. If the guard touches the frame because the supplied spacer isn't long enough (the usual scenario) add enough washers on each side for the guard to clear the frame. The guard should be tight against the spacer or washer, not the frame. The frame is grounded. It should not be used to ground electrical items though.
post #6 of 10 Old 04-16-2007, 10:16 AM Thread Starter
cmosentine's Avatar
.... add enough washers on each side for the guard to clear the frame. The guard should be tight against the spacer or washer, not the frame. The frame is grounded. It should not be used to ground electrical items though.
I'm sure this will make perfect sense once I begin the install, but when you say frame do mean the "frame other than the mounting points?
Chris
2008 HD FLSTF
post #7 of 10 Old 04-16-2007, 10:48 AM
Chris
Yes. The spacer rests against the large adjuster collar inside a large hole in the V shaped aluminum frame member. If the guard touches the V shaped frame member, the tab will be stressed. Use the washer(s) supplied to make sure the guard only touches the spacer or washer, not the V member. Hold off on more questions until you actually try it. You're starting to obsess on a very simple job. If you still aren't sure when you are actually doing the job, then ask.
post #8 of 10 Old 04-16-2007, 11:26 AM Thread Starter
cmosentine's Avatar
I be quiet now. Thanks, Chris.
2008 HD FLSTF
post #9 of 10 Old 04-18-2007, 09:40 PM Thread Starter
cmosentine's Avatar
Thumbs up Just an update and THANKS
After much hand wringing I installed the crashbars today. The entire job took me 45 minutes, and that was with getting the middle lower spacers reversed (left/right). I had no issue with the bars contacting the frame and therefore did not need to add any spacers.
The only thing that surprised me was the new "long" bolt was too long. It could have been 1/2 inch shorter. I now have to consider cutting some of this off.
Thanks to everyone for your assistance, Chris
2008 HD FLSTF
post #10 of 10 Old 04-19-2007, 05:57 AM
MZBuckeye's Avatar
I noticed the same thing. No spacer/washer issues, but the new bolt does stick out about 1/2 inch too far. I imagine this is so there's room to add spacers/washers if need be, but mine didn't need it.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
