Power Outlet - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-15-2013, 08:59 PM Thread Starter
Power Outlet
Ok I've had this bike for a bit and finally have a need to plug in a phone or other to charge. What power outlets would you recommend? I have not clue as to brand/model. What about the amps? I'm hoping to get a GPS also. Do I hard wire this in? Can I add more than one outlet without a problem? What's best?
Thanks in advance!
Mike
"2 Tens for a Five?" Anyone?
2wheelfun is offline
post #2 of 10 Old 05-16-2013, 10:59 AM
Well a search in the little google box at the top of the page will lead you to links for outlets.
BMW style(John Deere like) or an automotive cigarette lighter. Best get a water resistant one from a boat shop. Run a line to the battery and fuse it near the battery.
I have a pig tail cord for those charge the phone and run the GPS moments. Most accessories don't draw much power but the occasional use of the tire pump will require 10-15 amp fuse. Use big fat wires from the battery.
Where you mount it is a personal quandary. I tie wrapped mine to the cable guide on the clutch side. Others drill holes in the dash plastic. Some put it higher on a shelf above the instruments. Depends on how long your arms are.
post #3 of 10 Old 05-17-2013, 07:51 AM
I do all my charging in my tank bag. My GPS, Ipod, Phone run power to the tank bag.
eddie98 is offline
post #4 of 10 Old 05-17-2013, 11:11 AM
"do all my charging in my tank bag"
RKA makes an outlet friendly tank bag or DYI, Still needs a power and ground line, fused of course, from the battery.
There's just so many possibilities out there.
post #5 of 10 Old 05-17-2013, 01:31 PM
Amuro Lee's Avatar
I installed the OEM socket
https://www.stromtrooper.com/1195193-post10.html
and use it to charge my iPhone which is used as an GPS device.
https://www.stromtrooper.com/1203289-post12.html
Amuro Lee is offline
post #6 of 10 Old 05-21-2013, 10:55 AM Thread Starter
Thanks to all the responses and for the information. I'm off and running.
Mike
Mike
post #7 of 10 Old 05-21-2013, 05:48 PM
I used the connectors that they sell for the Battery Tender, to attach to your battery. Then the 12 V socket that they sell that connects to it. Very easy, no wiring, just plug it in and route the wires.
I was able to fit the actual socket in the wire loop for the clutch cable by bending it open a little bit.
2012 V Strom 650 "Stromtrooper White"
RobT2K is offline
post #8 of 10 Old 05-21-2013, 06:00 PM
Could you give me a little more info on the outlet you bought? I already have the fused battery tender plug installed.
dkayak1 is offline
post #9 of 10 Old 06-25-2013, 07:00 PM
Surplustravis's Avatar
sometimes cycle gear has their waterproof handel bar mounted 12v outlet on sale for $9.99 I got one and love it it looks good also
Surplustravis is offline
post #10 of 10 Old 06-26-2013, 02:10 PM
Capt_phun's Avatar
I use the battery tender 12v outlet. I also have the heated gear coax ax mounted that I can plug another SAE plug into for a 2nd outlet if more power is needed. In the front 12v outlet I use a 2 port usb that powers both my GPS and charges my phone. The male plug with 2 usb ports was $10 at Eastern Mtn Sports.
DL650 Adventure Trax Box Carrying Handles/Lashing straps. --> click link to view info & how to order: [url]https://www.stromtrooper.com/dl650-2012/80136-trax-box-carry-handles-lashing-straps.html[/url]
Capt_phun is offline
