Question about silicone - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 04-12-2007, 12:06 AM Thread Starter
I recently got some soft saddlebags but unfortunately they will be resting on my Leo Vince exhausts, which get really hot while riding. In researching options to keep them off the exhaust, my fiance suggested cutting and fitting some of that silicone bakeware stuff and attaching it to the part of the bag that will be resting on the pipes. I think it's a great idea but am not knowledgable enough about silicone to know if it will effectively keep the heat from coming through. Any silicone experts out there?
2006 dl1000- grey
"A man is a success if he gets up in the morning and he gets to bed at night, and in between he does what he wants to." - Bob Dylan
"Happiness is nothing more than good health and a bad memory." -Albert Schweitzer
"What we have to learn to do, we learn by doing."- Aristotle
bigtallguy is offline
post #2 of 22 Old 04-12-2007, 12:34 AM
Talking Hmmm
That stuff may work. All you need to do is to check out the specs. I believe they are good for several hundred deg.
You could probably use some aluminized tape that they use to insulate different parts of vehicles (exhaust as an example). It usually has a sticky side. Stick it to you bags with aluminum side facing muffler. If one layer won't do it try 2.
Another alternative is sw-motech "universal" (www.sw-motech.com) side mounting kits that should allow you mount almost any (popular) case you wanted to.
Tray
06 DL1000
Tray is offline
post #3 of 22 Old 04-12-2007, 12:06 PM
Tollster's Avatar
I think if you could make some type of aluminum bracket to stand off the exhaust you would be better off. I have seen some at other sites that looked good. Then you have the airspace to faciliate keeping everything cool.
If you choose the bakeware idea, try a high temp RTV silicon, (I think they have black, but seem to remmeber seeing allot of funk off red colors for this app.) perhaps a header or exhaust type from permatex, then apply to both sides, the bake ware and the bag. First use the backing you have from the bakeware as a template. Using some type of delible marker, draw the outline or pattern onto the bag contact area, then clean the bag throughly with Cotol http://www.aerostich.com/product.php...cat=401&page=1
or perhaps rubbing alcohol, depending on what they are made of. I am assuming denier. Then use a short brissle stiff nylon brush work the ATV into the denier, apply another portion to the Bakeware, then put it ont the bag, maintain pressure for a period of time with soemthing like a large book.
My spelling sucks, i am sorry and thank all of you for not hammering me. I get ahead of myself and never learned to type. If you only knew what i did to make a living. After reading this post, I am starting to think I am dislexic at times. And I am sick of the edit button! Old age perhaps? To relient on spell check...perhaps...but you will know when I slept at the holiday inn express, it just wasn't last night
Tollster is offline
post #4 of 22 Old 04-12-2007, 12:14 PM
Keith Falkner's Avatar
Air is a good insulator. It's light and cheap.
I think the idea of an air gap is excellent. After all, Mrs. Suzuki installed two of them there when she built your DL1000.
If you still have those stock plastic shields, and can fasten them to the new mufflers, I think you will have a winner. In my opinion, those shields are made to get scuffed. They are a cinch to repaint.
I understand the left ones are a bitch to remove and install, but I don't have one of those.
Keith
Keith Falkner is online now
post #5 of 22 Old 04-12-2007, 12:15 PM
i'd go with exhaust wrap, which you can buy from JC Whitney:
http://www.jcwhitney.com/autoparts/B...8048142/VT-sch
i used it on the exhaust headers of a triumph sprint, to hide how beat up they were. works great.
TouringDude is offline
post #6 of 22 Old 04-12-2007, 01:28 PM
I have the exact same problem! I just bought some Nelson-Riggs bags but I have a Staintune pipe on my bike with no heat shield.
If you come up with a relatively cheap solution, please let me know.
I'm going to try and make a stand-off with some scrap aluminum from the metal shop here at work. If that works well, I'll take some pics and show you what I come up with.
Brian
troxelb is offline
post #7 of 22 Old 04-12-2007, 01:44 PM
Wee_Willie's Avatar
Here's a solution that NoVa-strom came up with. Granted, it's on one side of a 6fiddy, but you get the idea...
https://www.stromtrooper.com/forums/s...t=soft+luggage
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #8 of 22 Old 04-12-2007, 01:51 PM
Wee-Willie,
That is pretty much what I'm going to attempt.
BigTallGuy,
The only problem I could see with the silicone idea would be that if you have silicone in contact with heat, it will heat up. It won't melt, but it may get hot enough to melt the soft bag. I don't know how hot it will get, but from experience with a silicone oven mitt, if you hold on to a hot pan for a while, the mitt gets HOT!
Brian
troxelb is offline
post #9 of 22 Old 04-12-2007, 01:51 PM
Wee_Willie's Avatar
Oh Yeah, before Heavy says it, "Use the Search fuction at the top of the page". The link you see above was the the result of a "Show Posts" for "Soft Luggage".
No Hostility meant... Search is your friend!!
IBA#27466
post #10 of 22 Old 04-12-2007, 02:05 PM Thread Starter
Yeah, I searched but am trying to come up with something that will be easily removable (without tools) since I won't ride with the bags on all the time. I had another idea of putting together some type of clamp to mount on the passenger hand holds with some aluminum or something going down over the pipes from there. I gotta go to the hardware store and browse.....
2006 dl1000- grey
