gp shift - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-10-2007, 08:15 PM Thread Starter
randyo's Avatar
gp shift
I've been wondering if it's practical to flip the shift linkage on the strom (1k) , I prefer 1up/5down but the angle of the shift linkage looks a bit funky and might bind easily
has anyone tried ?
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 9 Old 04-10-2007, 08:49 PM
DraganeeRacing's Avatar
very easy to do . Each of my race bikes (GSXR/SV) use the GP pattern. Just mark the position on the shifter on the shaft( in case you wish to return it to factory) and flip the arm. You can adjust the lever position but loosening the 2 nuts and turning the "screw" to raise or lower the shifter to your liking.
"...roadracing motorcycles makes heroin addiction look like a vague wish for something salty..." P.E
DraganeeRacing is offline
post #3 of 9 Old 04-10-2007, 08:50 PM
A Touratech folding shift lever will do exactly that. It fits directly on the shifter shaft.
post #4 of 9 Old 04-10-2007, 09:43 PM Thread Starter
randyo's Avatar
Originally Posted by DraganeeRacing View Post
very easy to do . Each ]
Yes, I know how it is done, my SV is setup that way, and it has become a pattern I prefer
it does not look as simple on the V-Strom, the linkage rod comes down at a steep angle, not near perpendicular like the SV, flipping the lever on the shaft appears as though it might severly stress the limits of the linkage motion and be cause for false neutrals, mossed shifts etc.
I have to check out the Touratech shifter that greywolf speaks of
what are the disadvantages of going to a linkageless shifter , will potentially the shift shaft bushings etc. wear quicker, am I looking to create an eventual oil leak ?
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #5 of 9 Old 04-10-2007, 10:48 PM
Not a problem. Heim joint links enable the shift lever to be placed in any position and adjusted in fine increments.
post #6 of 9 Old 04-11-2007, 04:40 AM
BooneDog's Avatar
Touratech Shifter does NOT change shift pattern on 1000
"I have to check out the Touratech shifter that greywolf speaks of "
That shifter does change the pattern on the 650, but NOT on the 1000.
Isn't that what you are asking about? The two linkages are not the same.
That's why Touratech says the shifter will fit the 1000, but is not for the 650. It's not that it won't fit, it will, but it'll change the shift pattern(on the 650)
BooneDog
[url]www.irun100s.com/daveharper[/url]
BooneDog is offline
post #7 of 9 Old 04-11-2007, 07:28 AM
Dang. Screwed up again. I even looked up the part fiche to make sure the 1000 also used linkage but didn't see the shaft connection was up on one bike and down on the other. It was indeed past posts on the shift pattern reversing on the 650 that got me started.
post #8 of 9 Old 04-11-2007, 08:55 AM Thread Starter
randyo's Avatar
thanks for pointing that out before I ordered it
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #9 of 9 Old 04-11-2007, 12:34 PM
If you had. I would have paid your shipping and restocking fees. It was my fault.
