Heated grip problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 04-08-2007, 11:54 PM Thread Starter
Heated grip problem
Ok, so here's the deal. Finally got my wiring maze straightened out and thought I finally had heated grips. Symtec grip heaters by the way. Throttle side heats up like a charm. Clutch side is cold on both Hi and Lo settings. I am leaning towards a bad ground wire in the harness part of the grip heater, possibly a broken or pinched wire during manufacture. Before I start tearing the left side apart has anyone had a similar problem. Any hints or suggestions would be a bonus. I am so close to having everything done on the to-do list. Thanks in advance.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 17 Old 04-09-2007, 12:37 AM
It depends on your present wiring what would be easiest to do. One thing is to check if the wires from the bad grip have resistance. If you don't have a volt-ohm meter, you can even take the two wires from the grip and see if you can get a spark touching the terminals of a nine volt battery with each wire.
post #3 of 17 Old 04-09-2007, 01:31 AM Thread Starter
Greywolf, if I had been real smart I would have tested the heating elements before installation. My bad of course. But of course I am just being human and trusting that all is well with a new product in a package. Oh well, what else do I have to do this time of night. Down to the Bat Cave.
05 / 650 in blue
75/Suzuki 125 RV
post #4 of 17 Old 04-09-2007, 06:21 AM
Mr. Fisherman's Avatar
Let us know how it turns out...
Live to ride,
ride to live
Bunch of TOOLS Fan Club member
Mr. Fisherman is offline
post #5 of 17 Old 04-09-2007, 08:19 AM Thread Starter
OK, so here's the deal. I AM DONE.........Finished !!! Spent the night in the Bat Cave just doing what I should have done first time round. Undid all the wire connectors and replaced them carefully just to make sure they were all good. Tested each heating element with a fused wire from the battery. Hi/Lo work on both sides although the left side takes much longer b/cause of the heat sink effect of the bar. Probably won't be as warm overall but I can live with that.
On a roll now. Getter done, head for the handguards and strangely enough I had a break through. They are on too. Have one washer left over but according to the instructions everything is where it should be. Leaving well enough alone. I might have attracted a spare washer from my junk bin. Did some adjusting on the mirrors since I put the 2 inch extensions a little while ago. The stem or arms where so tight I though something was going to break.
Now I can ride and test everything out for real under real conditions. None of this Bat Cave stuff for a while hopefully. Time for sleep. Good Night.
P.S. Thanks for putting up with my whining and sniveling, it's one of the only things I am good at doing.
05 / 650 in blue
75/Suzuki 125 RV
post #6 of 17 Old 04-09-2007, 08:22 AM
Heavy's Avatar
Congrats WW.
Do a couple of twisties for me when you get out there.
DL1000K6
Heavy is offline
post #7 of 17 Old 04-09-2007, 08:30 AM Thread Starter
Heavy, were you waiting for me to finish ?? I know it is later in the morning for you but really............Thanks.
05 / 650 in blue
75/Suzuki 125 RV
post #8 of 17 Old 04-09-2007, 08:35 AM
tmcgee's Avatar
Never underestimate the power of whining and sniveling. It's a hell of a lot of fun, just like grousing, which is my favorite method! :rolleyes:
tmcgee is offline
post #9 of 17 Old 04-09-2007, 08:37 AM
Heavy's Avatar
Actually, you are my morning motivation....I'm just about the head out to the (very well lit, unlike the BatCave) garage to begin preparing my Strom for the coming season.
DL1000K6
Heavy is offline
post #10 of 17 Old 04-09-2007, 08:43 AM
Glad it all came together.
Now you owe us a ride and a ride report...
:mrgreen:
Live to ride,
ride to live
