How low can you go??? Vortex Lowering Links - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 04-06-2007, 07:04 PM Thread Starter
Arrfy's Avatar
I want to lower my stock 05 Wee as much as is safe and doable(the two are not always the same, yes?) I'm 5'9" and the more firmly my feet are planted on the ground, the better I feel. My local dealership has Vortex Lowering Links that claim either 2" or 4" lowering. So far, I have only read of people lowering the bike up to 3/4" or so. Can you actually go 2"-4"?
If so, what other things must be adjusted to compensate and keep the bike safe and shiny side up?
Thanks!
Arrfy is offline
post #2 of 16 Old 04-06-2007, 07:24 PM
chris swann's Avatar
i am 5,9 and can plant both feet flat on the ground,im used too tip towing it on my honda xrl,i would like too raise my bike a bit not lower it,just curious why do you need to make it low
swann strom
chris swann is offline
post #3 of 16 Old 04-06-2007, 07:25 PM
K1W1's Avatar
I think 2" or more would be a huge problem as far as suspension travel and steering angles were concerned.
I'm 5'9" as well and have no problems at all riding a Wee but I guess it's just a confidence thing. If you do want to lower the bike I suggest the 3/4" that most people use would be the safest, then get a lower seat if you need more. If that combination is not enough then I think you should seriously consider whether the Wee is the correct bike for you.
K1W1 is offline
post #4 of 16 Old 04-06-2007, 08:04 PM Thread Starter
Arrfy's Avatar
Unhappy
I suppose to some degree it's a confidence thing. I dropped the bike in a situation that might've been avoided with a little lower gravity...then again, I could be fooling myself and it was just one of those things.
Pardon my newbie-ness, but when people say lowering by 3/4", do they mean raising the front forks in addition to installing lowering links in the rear?
Arrfy is offline
post #5 of 16 Old 04-06-2007, 08:12 PM
Unpleasant things happen when the tire crashes into the fender. Kouba links lower the back 1 1/8" and they allow contact on really big bumps.
post #6 of 16 Old 04-06-2007, 08:23 PM
K1W1's Avatar
Yes if you lower the back you also need to lower the front to keep the geometry correct.
K1W1 is offline
post #7 of 16 Old 04-06-2007, 08:32 PM
SCraig's Avatar
I also think that if you lowered it 4" the sidestand would make it lean the wrong way!
Scott Craig - Nashville, TN
SCraig is offline
post #8 of 16 Old 04-06-2007, 10:08 PM
Stromtrooper for Life Godspeed Jay
JayR's Avatar
I lowered the front 3/4" and the rear by 1". I like it lowered for my easy commute, but I am thinking of going back to stock height for a trip in May. Besides my time being wasted is there anything wrong with me spending the time to install the original links?
Global Warming, because a populace on foot is easier to control. They can take the keys to my fire breathing, CO2 belching, Strom and other cylinders from my cold dead hands.
2006 Suzuki DL1000
JayR is offline
post #9 of 16 Old 04-07-2007, 04:42 AM
Have Koubalinks on the Wee and the forks raised up about 22 mm. Feels more comfortable height wise and the center of gravity is a little lower too. Happy I made the changes.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #10 of 16 Old 04-07-2007, 05:07 AM
I'm 5'8" and can't stand flat footed on it but don't think i'll need to lower it. I have yet to pack it down with a hundred pounds of camping gear and other crap well see, but compared to my last bike a honda vtx 1800 this thing feels like a moped. I wouldn't think you would need more then 3/4 to an 1 inch of lowering.
Tim
majicbus is offline
