Fenda extender mounting ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 04-02-2007, 10:16 AM Thread Starter
cmosentine's Avatar
Howdy: My Fenda Extender should be arriving this week. I have not seen the mounting instructions, but I can say I would prefer not drilling my fender. I think I remember reading on these hallowed pages that it can be installed with pvc cement/glue. This true?
How did you mount your extender?
Thanks much, Chris.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #2 of 25 Old 04-02-2007, 10:18 AM
Reverendbiker's Avatar
I've mounted them on four different bikes, using PVC cenent every time. Haven't had one come loose yet...
Fenda Extenda
jack <><
'07 DL650, "which may just be the most shockingly competent machine in the world today"--Cycle World
www.reverendbiker.com
Reverendbiker is offline
post #3 of 25 Old 04-02-2007, 10:32 AM Thread Starter
cmosentine's Avatar
Fenda Extenda
Just to be clear, the pvc cement you used is the same stuff I use to on plumbing?
Also, did you remove the fender to do the installation?
Chris
2008 HD FLSTF
post #4 of 25 Old 04-02-2007, 11:18 AM
Martin's Avatar
Chris
Hello,
I used regular "Goop" household contact cement, no screws, and mine is sticking together just fine, but I would have preferred a more "industrial-strength" glue.
I took my fender off for this off-season project but it picked up some nasty scratches in the process. I tried to compress the fender sides to slip it between the forks but it still got scratched both going off and on. The scratches might buff out, I dunno.
It may be possible to glue on a Fenda-Extenda with the fender mounted but I think the inside of the fender has to really be pristine if you're just going to rely on glue. It may be hard to scrub it clean enough while it's mounted and it might be difficult to get clamps to hold everything together while the glue sets up but I think I would try it that way first. Maybe test-fit it first to see if it might work.
If you do remove the fender watch out that the captive nuts inside don't fall out and bounce away. One of mine did AFTER I had already gotten the fender back thru the forks and I could not bear the thought of scratching the fender even more so I taped the nut to the end of a stick and managed to get the bolt thru it after about an hour of fishing around. What a PITA that was.
1/2 hour project = 1.5 hours for me
- Martin
2019 650X
Martin is offline
post #5 of 25 Old 04-02-2007, 12:53 PM
bobosmite's Avatar
Yes, PVC cement from the plumbing section of your local hardware store. Read the warning label because this stuff puts off some super toxic fumes. Cross-hatch the fenda extenda with a utility knife to rough up the surface and stick it right on. Get a couple soft clamps to hold it in place.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #6 of 25 Old 04-02-2007, 02:23 PM
I use a combination PVC/ABS cement from Home Depot and it works like a charm.
jack <><
post #7 of 25 Old 04-02-2007, 03:35 PM
Here's my 2 cents worth on mounting the Fender Extender. If you don't want to drill your fender and choose to use adhesive, what happens if something damages the extender and you'd like to replace it. How are you going to get it off? I went to the local home supply store and bought 4 8-32 stainless machine screws, nuts and washers. It only takes a small hole for an 8-32 and in the future if you decide to remove or replace it only takes a minute to get it off. And beside that you can't see down behind the fender anyway so you don't even notice them.
p.s. look at the thread about the powder coated wheels. I have some pictures in there of my bike with the extender on it. You can just make out the screw heads in the picture. Not obtrusive at all.
gbritnell
gbritnell is offline
post #8 of 25 Old 04-02-2007, 09:01 PM
$Whatever$
Heavy-H's Avatar
Originally Posted by Martin View Post
Hello,
- Martin
Yea.........What he said!
06-DL1000 62000 miles....Sold...
Now 2012 Honda NC700X..37500 and counting...............FOR SALE
Now 2005 Suzuki Hayabusa..25000 and counting.......
Now 2018 Yamaha Super Tenere ES........
Heavy-H is offline
post #9 of 25 Old 04-02-2007, 09:17 PM
I used a super strong 3M double sided tape. It's not the regular double sided white foam tape with the white with green hatched peel off backing (although that's quite strong itself). The stuff I got was thinner black foam with red colored backing. It's been over a 1,000 miles and it hasn't budged one bit. Just make sure you clean and prep the surfaces if you choose to go with adhesive tape.
And I removed the fender to get better access. I happened to have my front wheel and brake assemblies removed so it was a cinch to remove the fender without mucking it up.
DL650K4
TrunkMonkey is offline
post #10 of 25 Old 04-02-2007, 10:24 PM
BumbleBee's Avatar
uh, I guess I should have read this thread, I used their crappy tape and four 1/8" rivets, and some black model paint.
03' yellow dl1000 Rich's seat, custom built racks with ortieb drybags
givi crash bars, powercommander,mm spacers,SV slipper clutch
43t sprocket, speedohealer custom 04'+MpDesigns/madstad windscreen
BumbleBee is offline
