Center stand springs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 04-01-2007, 12:34 PM Thread Starter
I installed a Hepco and Becker center stand a few months ago. It seems the center stand does not go all the way up when I take it off. I have to finish putting it in the up position manually. The springs are attached correctly. Anyone have a reason this happens? Anyone else seen this problem?
"What can will go wrong".
07 V-Strom 650
03 Yamaha FJR 1300
Its loaded to the max.
FJR/V-strom trooper is offline
post #2 of 7 Old 04-01-2007, 01:01 PM
Did you grease the pivots? Does it have two springs, one inside the other, like the OEM and SW-Motech?
post #3 of 7 Old 04-01-2007, 01:14 PM
Crazy Old Guy
fastwally's Avatar
Does the Hepco Becker have bushings and are they on the correct sides?
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #4 of 7 Old 04-01-2007, 05:54 PM Thread Starter
Yes the springs are two, one inside the other. I believe the bushings are the same and installed on the correct side when installing according to instructions, German for what the pictures are worth. I will to grease the pivot points. Before I pushed the send button I went out and greased the pivot pints then cleaned the chain. Seems to move better on the pivots. I think some of the powder coat must be worked over and wear in. thanks.
07 V-Strom 650
03 Yamaha FJR 1300
post #5 of 7 Old 04-07-2007, 09:47 AM
MATTMAN's Avatar
My SW Motec stand did the same thing. The directions said to grease it and I forgot. I sprayed same chain lube on the pivot point and all was better.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #6 of 7 Old 04-08-2007, 03:25 PM
Lightbulb
Try loosening the center pivot bolt just a little. See if that will allow it to move freely.
Good luck.
06 DL1000 Red -
"shifts smoother with those mirror extenders!"
00 xr650l -
01 TW200 - resort cruiser
tucsonstrom is offline
post #7 of 7 Old 04-09-2007, 01:57 PM
Tollster's Avatar
I would remove the bolts, use some blue loctite and retorque to the spec included in the instructions.It would not hurt to remove the paint while its disasembled, then regrease.
Tollster is offline
