Fuel Injector Cleaner ???? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 03-27-2007, 08:49 AM Thread Starter
Send a message via AIM to zapp22 Send a message via MSN to zapp22 Send a message via Yahoo to zapp22
Folks
I was getting around 50mpg, then suddenly I dumped down to about 41 and can't figure out why. everything runs well, and I am not doing anything diff gas-wise or right-hand-wise or terrain-wise. So I think I'll run some strong Fuel Injector cleaner for a tank and see what happens afterward.
Any suggestions on which chem to use, and how concentrated?
z
DL650K5 StealthBomber Flat-Black
DR650 'Ole'97 White! Dreamy
Memorial: K4 Weestrom [terrific]; '00 XRR/BRP; '02 DR650; '01 DRZ400E; '01 Shadow Spirit 1100; '00 Shadow Sabre 1100; '02 Roadstar Midnight; ancient PE250, DT360!!![my first "Dual-Sport"]
zapp22 is offline
post #2 of 19 Old 03-27-2007, 10:38 AM
Crazy Old Guy
fastwally's Avatar
Have you checked the air filter?
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #3 of 19 Old 03-27-2007, 10:54 AM Thread Starter
yep. first thing I did, and pulled the plug to check. color looks fine, and the filter was average.. just dry dust and the odd bug. I cleaned it out and put back in.... it was new about 1500 miles ago. whilst there I pulled the boot off. made no difference whatsoever. 41mpg.
zapp22 is offline
post #4 of 19 Old 03-27-2007, 07:54 PM
zed88's Avatar
Send a message via AIM to zed88
I'm having the same problem at the moment. Before I was getting 52-55mpg, and now I'm getting between 41-44. I think that we might still be on winter gas (??) and I've been filling up at different pumps, and each one fills to a different level. The bike runs great, but I want my gas mileage back! I've checked to make sure nothing is dragging, brakes or etc and all appears to be well. The bike was running 50+mpg around 15k miles, and now I've just passed 16k. Oil, filter, and plugs all appear to be just fine. All are new within the past 1500 miles.
Would a throttle body sync cause this? (I'm paranoid and can't check it at the moment).
What kind of trouble could cause such a large drop in mileage?
Thanks!
Eric
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #5 of 19 Old 03-27-2007, 09:53 PM Thread Starter
nawwwww...
TBS is overrated.
when you sync TB's, there are a lot of variables:
- how warm/hot is the engine?
- while warming is it sitting still or moving? there's a diff in the heat of the rear versus front cyl, and it affects the vaccuum reading
- is the rear cyl OVERheated???? gotta hit the seam
- check at idle, at 4000rpm, at 60000 rpm?????
- make sure the tubes are equal length and take time to tap the air out of the manometer.
- make sure you don't just sync at one rpm setting [see above]
get the picture?
Thanks!
Eric
zapp22 is offline
post #6 of 19 Old 03-27-2007, 10:14 PM
WeThereYet's Avatar
Originally Posted by zapp22 View Post
nawwwww...
TBS is overrated.
get the picture?
Wow, all that? Who knew! I bet you are putting more thought into it than anyone else here. Just plug your tubes on and do it.
WeThereYet is offline
post #7 of 19 Old 03-28-2007, 07:38 AM Thread Starter
already done.
thanks for the valuable contribution
zapp22 is offline
post #8 of 19 Old 03-28-2007, 08:29 AM
Rjsurfer
Could it be the gas? different brand or blend?
Ron W.
rjsurfer is offline
post #9 of 19 Old 03-28-2007, 09:14 AM
nawwwww...
TBS is overrated.
get the picture?
Not sure I agree with you on that! You are the one who is creating all the variables. I just did a TBS adjustment for a member last weekend, try to convince him that "your" variables had a negative effect.
I am not sure why you guys are getting the sudden drop in mileage. How hot has it been, I see you guys live out West. My mileage honestly doesn't fluctuate much, guess I am lucky.
Big B is online now
post #10 of 19 Old 03-29-2007, 04:49 PM
mileage
I don't know where all of you are but here in Kentucky we change to a winter blend which makes EVERYTHING suffer. If I've been riding all winter I will see a change come about sometime in April...maybe you suffer from the same!
woodly1069 is offline
