Wee 16 Tooth Sprocket Mod Vibrations??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-25-2007, 11:20 PM Thread Starter
For anyone that has done the 16 Tooth sprocket mod with the standard cheap sprocket, have you noticed any additional noise or vibrations? I am going to do this mod and I am trying to decide if I need to spring for the extra bucks to get the sprocket with the rubber damper. (GSXR 600)
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #2 of 7 Old 03-25-2007, 11:29 PM
Rjsurfer
I made the 16 tooth sprocket upgrade on my DRZ 400SM and found NO additional vibration or noise. It too had a rubber bushing on the factory sprocket but none on the new one.
Ron W.
rjsurfer is offline
post #3 of 7 Old 03-26-2007, 12:13 AM
nvr2old's Avatar
I've got the 16 tooth w/o the rubber dampner and have not had any problem with vibration. Great mod for highway use.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 7 Old 03-26-2007, 02:45 PM
Reverendbiker's Avatar
I've used an aftermarket 16T sprocket and the GSXR 16T sprocket with the rubber insert:
http://www.reverendbiker.com/vstrom/sprocket.htm
Honestly, I can't tell the difference between the two--no noise or vibration with either. Caution here: I'm an old codger who's survived many rock concerts since the 60's, so there are lots of noises that don't bother me
jack <><
'07 DL650, "which may just be the most shockingly competent machine in the world today"--Cycle World
Reverendbiker is offline
post #5 of 7 Old 03-26-2007, 05:14 PM
PonchoV's Avatar
Well done. I did the same late in 06 & never looked back. Plenty of power even 2 up. The milage improvement is equal to mine. I guess that makes us part of the 'green' groupies.:rolleyes:
PonchoV is offline
post #6 of 7 Old 03-26-2007, 05:53 PM Thread Starter
Thumbs up
Thanks everone, I guess I will save the bucks and buy the standard sprocket. I commute a lot at 70-80 MPH and find myself looking for that extra gear every once in a while, and if I get an MPG increase that will be icing on the cake. The only reason I thought it might vibrate or be noisy is because ReverendBiker mentioned in his site that some people have noticed it. Great site buy the way, and your pics and instructions will come in handy when I make the swap. Thanks ReverendBiker.
Kevin
khager is offline
post #7 of 7 Old 03-27-2007, 08:47 AM
Send a message via AIM to zapp22 Send a message via MSN to zapp22 Send a message via Yahoo to zapp22
16T should have been standard IMHO. Best mod I have put on. I run a 'sprocket specialties', no rubber, very smooth.
DL650K5 StealthBomber Flat-Black
DR650 'Ole'97 White! Dreamy
Memorial: K4 Weestrom [terrific]; '00 XRR/BRP; '02 DR650; '01 DRZ400E; '01 Shadow Spirit 1100; '00 Shadow Sabre 1100; '02 Roadstar Midnight; ancient PE250, DT360!!![my first "Dual-Sport"]
zapp22 is offline
