ending buffeting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 116 Old 03-25-2007, 05:17 PM Thread Starter
JONNYREB's Avatar
ending buffeting
Having tried the stock shield in all positions, i found the lowest position to induce less buffeting. I had gotten the idea from monkeygrass to cut the stock shield down so as to let clean wind hit you without the buffeting, but did'nt really want to cut mine so...I found another possible answer.
By lowering the factory shield so that the mounting pegs were holding the screen through the third set of holes(from the bottom up), and redrilling the four holes for the mounting screws, i was able to lower the stock screen down about two more inch's. I then had to redrill the two holes for the two mounting bolt covers little stabilizer pegs. By drilling these 6 holes i was able to retain all factory mounts, shield and screws. It brings out more of a sportbike look and lets the wind hit your upper body without much turbulence.
I tried the new height setting at all legal highway speeds and it seems like a good summertime solution. One drawback is that the screen can't go back to the factory height without the newly drilled hole on top showing. As i use a givi in the winter it won't be an issue. J.R.
06' 650
JONNYREB is offline
post #2 of 116 Old 03-25-2007, 07:57 PM
icanfixthat's Avatar
Sounds interesting. As my stock screen is great in the lowest position, except 60 MPH+, this might be an option for me. Plus it's free, and I'm, uh, thrifty. Any pictures?
icanfixthat is offline
post #3 of 116 Old 03-25-2007, 09:46 PM
Newfoundlander's Avatar
Yes, photos would be nice. Sounds promising.
I'm going to add an experiment of my own to the buffet-issue's body of knowledge...
I noticed the dreaded effect above 60 mph, with the screen in the lowest position. But many wise folks on this forum have suggested that the problem may be more related to helmet type than we realize. So since I have a brand new and more aerodynamic HJC SP-CL helmet on the way, I'll post back here and report on how much of a difference it makes over my current seven year old KBC helmet's design.
The HJC SP-CL is quite aerodynamic looking, and also has a spoiler on the rear, which HJC claims helps reduce turbulence around the helmet. We shall see if it lives up to the hype, or not...
2008 Yamaha FZ1
2009 Kawasaki KLX450R
Newfoundlander is offline
post #4 of 116 Old 03-25-2007, 10:17 PM Thread Starter
JONNYREB's Avatar
Sorry i have not yet figured out the digital camera so until my wife takes the shots i can't do the pics. Pitiful excuse but true. I'll work on that.
If you take your 2 bolt covers off your factory shield and then remove the 4 factory bolts that hold the screen on, you can then hang the screen on the 2 pegs at the position you want. At this point you can see what it will look like before you start drilling. Only takes a minute with a phillips head screwdriver .If you go ahead with it, use the holes as a templet and drill a pilot hole with a tiny bit in the dead center of the mounting holes(4)
Then take the shield off the bike to drill the full sized holes.
Yes Newfoundlander i agree with you about the helmet effect, i found my new scorpion helmet is WAY better on the interstate than my fulmer. It made a big difference. goodluck J.R
JONNYREB is offline
post #5 of 116 Old 03-26-2007, 06:52 AM
Just take the wind screen off, problem gone looks a bit odd though.
Mick
04 R1 Silver
07 DL650 Red
08 B-King Black
Red dust is offline
post #6 of 116 Old 03-26-2007, 10:55 AM
With the MadStad bracket, I don't know why people even discuss buffeting and all these other "solutions" any longer. The MadStad should come as standard oem equipment.
-dennis
2006 DL650 Silver Blue
2004 Triumph Thruxton
d2mini is offline
post #7 of 116 Old 03-26-2007, 11:31 AM
does the madstad work well with the stock shield? i've been wondering.
TouringDude is offline
post #8 of 116 Old 03-26-2007, 11:35 AM
When the madstad came out I already had an mp cycle designs screen so i never used the bracket with stock. But from what I hear the bracket makes a VAST improvement regardless. For 60 bucks or whatever it costs now it's a no-brainer.
-dennis
d2mini is offline
post #9 of 116 Old 03-26-2007, 12:21 PM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
I have a madstad on order, but the price of the new version is $80. I hope it works. After my ride yesterday, I think that most if the turbulance is being generated by the mirrors. :???:
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #10 of 116 Old 03-26-2007, 12:28 PM
V1Vr's Avatar
Madstad + a Cee Bailey 23" screen is great for me. Put the stock shield on it and it is OK but still a little bit of head slap.(6ft/33"inseam). The only experience I had with stock mounts was on test ride and that was brutal, do not remember what setting they had it set at.
Blue DL650 k6
Better to remain silent and thought a fool than to speak out and remove all doubt, A. Lincoln
V1Vr is offline
