No more Amotostuff rack vibrations! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 03-23-2007, 10:44 PM Thread Starter
I have to give credit where credit is due... MightyShep gave me the info I needed to get rid of the rack vibration problems I was having, seen in this thread... https://www.stromtrooper.com/forums/s...ad.php?t=10003
Here is the results. It's the Universal Rack from Givi part# E250.
The top half of the amotostuff rack is removed. Long story short, that top half was vibrating so badly it was getting stress cracks straight through the aluminum. That part is replaced by the Givi part. Mounting the givi plate to the amotostuff plate, rather than mounting the givi directly to the strom rack, allows you to have some forward/backward mounting options for your top box. Just like the reason for having the amotostuff rack in the first place. I found the givi rack at my local bmw parts dept. Everything you need comes with it and it cost me $79. Which is a bummer since the amotostuff rack is faulty IMHO. MightShep had the exact same problems I did and his rack cracked as well. I might have to call amotostuff about this, even though I've had the rack for at least 6 months now. It just took me forever to diagnose where the vibrations were coming from. Someone else had mentioned that it was the unused embedded nuts in the top portion of the rack, but removing them didn't solve the problem. But no it's as quiet as a mouse again! Woot! Thanks, MightyShep!
Here's some pics of the new setup.
Bigger pics here...
http://d2creative.smugmug.com/photos/138141529-O.jpg
-dennis
2006 DL650 Silver Blue
2004 Triumph Thruxton
d2mini is offline
post #2 of 19 Old 03-23-2007, 10:52 PM
K1W1's Avatar
Did you the cover on the Givi plate after the photos were taken?
My cover vibrated so badly at 5000 RPM that a person riding beside me could hear it so I ended up removing it.
You could only hear the vibration when the top box was not fitted. I think the base of the box stopped the cover vibrating.
K1W1 is offline
post #3 of 19 Old 03-23-2007, 11:09 PM Thread Starter
Ya, i put the cover on after the pics. I wanted you to be able to see the screws.
-dennis
d2mini is offline
post #4 of 19 Old 03-23-2007, 11:16 PM
K1W1's Avatar
Does it vibrate?
K1W1 is offline
post #5 of 19 Old 03-24-2007, 11:17 AM
Send a message via AIM to kneedrachen
D2, just out of curiosity, as I was following the thread with great interest, could you accomplish the same thing (to avoid the problems you had) by buying their (amotostuff's) rear rack without the adjustable givi plate and then putting the E528 plate on it? Because thats pretty much what you did right?
'08 Yellow DL650
replaced
'06 Red DL650 with some goodies
kneedrachen is offline
post #6 of 19 Old 03-24-2007, 01:57 PM Thread Starter
Originally Posted by K1W1 View Post
Does it vibrate?
Not with the Givi box on top of it. I never ride without the box so I don't know if it vibrates that way. The cover is screwed down though, with the 4 supplied phillips screws.
-dennis
d2mini is offline
post #7 of 19 Old 03-24-2007, 01:58 PM Thread Starter
Ya, that's exactly what I ended up with.
Now i have the upper adjustable part, with stress cracks sitting on my work bench. :???:
-dennis
d2mini is offline
post #8 of 19 Old 03-24-2007, 05:01 PM
Live and learn. In a convoluted way, I have to thank you for your thread though since it has saved me some $ though, sorry it put you out....Glad I hadn't ordered the adjustable plate yet!
'08 Yellow DL650
replaced
post #9 of 19 Old 03-24-2007, 06:05 PM
K1W1's Avatar
Mine was the same (screwed down) but at 5000RPM without the top box (even standing still) it sounded like a buzz saw.
K1W1 is offline
post #10 of 19 Old 03-24-2007, 06:55 PM Thread Starter
Yeah, I believe it. I mean if the top rack was vibrating that bad, why wouldn't anything else back there. I wonder if this is why the oem strom rack is supplied with that rubber pad? I was talking to the guys servicing my bike today and they thought the amotostuff rack might benefit from some rubber mounts. Maybe big rubber gromets or something at the 4 points where the rack bolts to the strom. I might look into something like that...
-dennis
d2mini is offline
