OEM heated grips - are mine installed right? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-23-2007, 03:22 AM Thread Starter
bunner bob's Avatar
My heated grips are installed so that, on the throttle side, the wire sticks straight up from the front side of the grip, loops over the kill switch, then down to the bar from which point everything is fine. I asked Aurora Suzuki whether they couldn't be repositioned and they said no. I thought if you just rotated the grip 180 degrees so the wire dropped down at the back, instead of up at the front, everything would look much more tidy. But they said there was only one way it went together.
I started thinking - maybe the spool that hooks onto the throttle cables has two holes at around 180 degrees from each other, so why couldn't it just spin around, swap cables in holes, and be all good.
I can't help thinking they're wrong and the wire is supposed to drop off the back. Am I right or are they?
- Bob
2007 Wee-Strom ABS #1 - currently in Bedford, NY
2007 Wee-Strom ABS #2 - currently in Seattle
bunner bob is offline
post #2 of 5 Old 03-23-2007, 07:12 AM
I think they're right
I put my oem grips on myself and it looked like the only way they would go due to the cable end positions inside the throttle grip housing. I would be interested if anyone else has a different opinion since it does look a little untidy this way.
Good riding all.
Rick
Tex Rick is offline
post #3 of 5 Old 03-23-2007, 09:40 AM
The grips are not heated all the way around. They are probably set up for one position to get the heat in the right place.
post #4 of 5 Old 03-23-2007, 10:38 AM
MZBuckeye's Avatar
A picture of what you mean would help, but I think that's the only way you can install them.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #5 of 5 Old 03-23-2007, 02:10 PM
larolco's Avatar
Yup, that's how mine are set up - wire up and over.
DRZ400SK17
larolco is offline
