Brake caliper changes? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-26-2004, 05:40 PM
stormy
Hi all,
Has anyone replaced the stock VStrom (1000) front brake calipers with a more powerful unit, (from a 1200 Bandit for example or something similiar).
I have found that the stock set-up is adequate for the job, but not much else, and having done a lot of mountain passes this summer fully loaded, the brakes were at times, barely up to the one job they're supposed to do.
cheers for any tips.
Stormy
post #2 of 3 Old 09-26-2004, 10:54 PM
kawidan
try braided stainless lines if you haven't yet.they made a huge difference in feel and power.i'm really pleased with the results.the stock lines are about as good as that $6 garden hose for their flex and feedback.the galfer setup is what i mounted.your dealer can get it from tucker-rocky distributing.only place my dealer found it.i looked into caliper changes as i have access to some parts from other bikes,but the caliper mounting bolt layout really limits your choices.thought i had it made with a set of brembos from a duc but they won't mount up.
post #3 of 3 Old 09-27-2004, 02:50 PM
stormy
cheers!
Ok, I'll give the brake line change a go first, as if I still decide to replace the calipers later, I'll still need some brake lines anyway!
regards
Stormy
