Will a belly pan cause overheating? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-13-2007, 02:16 PM Thread Starter
I was wondering if anyone has experianced any overheating problems with a belly pan such as the style made by SW-Motech? It seems to me that even though there are holes cut in it, it would restrict the airflow to the oil cooler enough to cause a problem. Not to mention enclosing the header pipe in with it. I know many people have them but that doesnt mean they are not ignoring a potential problem. Has anybody with an oil temp. gauge installed, noticed much of a difference? Thanks
bobbyk is offline
post #2 of 6 Old 03-13-2007, 08:44 PM
Hmmmm....last time I checked, both Stroms were "liquid cooled", and oil cooled. You won't have any issues, go for it.
post #3 of 6 Old 03-27-2007, 08:56 PM
RedAnt's Avatar
I wouldn't worry about it either.
I've never heard of a Strom ever having anything but 3 bars on the temp gage. I did manage to get it to 2 bars once on the highway at 30F in 6th gear going downhill.
Obviously I live in the North and it doesn't really get HOT here. But my Pat Walsh skid plate doesn't have ANY holes for air and I added the extra radiator guard which is a plate with small holes. It claims to not restrict airflow, but I don't understand how that could be possible. I doubt I'll ever see it get hot.
Don't get me wrong. I actually like the Pat Walsh stuff a lot. I really like the highway bars and the fact it is a complete solution. I'm just pointing out that airflow doesn't seem to be an issue. Go ahead and pick a skidplate that looks rugged enough for what you intend to do to it.
DL650K6, MadStad adj shield, Givi e45 & e36, gpsmap 76CSx, Pat Walsh skid plate & bars, Sargent seat
2004 DRZ400S
[URL="http://www.sr.unh.edu/~rea/stromtrooper/2007/Strom_Range.png"]My 2007 Range map[/URL]
RedAnt is offline
post #4 of 6 Old 03-28-2007, 10:30 AM
Redbeard's Avatar
That's because you have a 650 - the 1000 usually rides at 2 bars, and goes up to 3 bars when you get stuck in traffic. I understand the 650 stays at 3 bars in regular use.
I have the SW-Moto skid plate, and my 1000 still rides at 2 bars, but when it goes up to 3 bars in traffic, it does take longer for the temp to drop back to 2 bars once you get moving. I don't think this is a problem, since it's not getting hotter than normal, it just stays there a little longer.
Take care,
Bob S.
DL1000K6 - Gray
Only motorcycle riders understand why dogs ride with their heads out the window.
Redbeard is offline
post #5 of 6 Old 03-29-2007, 04:46 PM
Belly Pan
I installed one on my bike about 10K ago and it's one of the best mods I ever did! You may want to check the alignment for the oil drain plug and make or enlarge a hole before installation. Just my two cents...
woodly1069 is offline
post #6 of 6 Old 03-30-2007, 09:10 PM
I have the SW-Motech Skid Plate on my '06. It was on my '05 before that. Never had a heat problem. 3 bars max.
You ain't bragging if you can do it
05 DL1000 (departed)
06 DL1000
jomawan is offline
