Easiest way to tighten back blinkers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-05-2011, 05:06 PM Thread Starter
CHUPACABRA's Avatar
Hello, kinda new here & this may be a stupid question. But does anyone have good advice on how to tighten the back blinkers. Or maybe a special tool for it without tearing half the bike apart.
CHUPACABRA is offline
post #2 of 8 Old 04-05-2011, 05:18 PM
Are yours coming apart or are you worried about how floppy they are? They should be somewhat mobile as they are rubber mounted. Can you turn the nut with your fingers?
post #3 of 8 Old 04-05-2011, 05:21 PM Thread Starter
CHUPACABRA's Avatar
Yes, the nut is loose. I can turn it with my fingers, but can't get a wrench to turn more than a 1/8 of a turn.
post #4 of 8 Old 04-05-2011, 05:51 PM
Flipping an open end wrench over usually changes the angle enough to make small bites work. I'd rather try that or take the rear fender off than find and buy a 12 point offset flare nut wrench that would be a perfect tool for the job, if such an animal exists. Give up one of those qualities if possible and such a thing can be found but take time and money to get.
post #5 of 8 Old 04-05-2011, 06:05 PM Thread Starter
CHUPACABRA's Avatar
Yup, figured that out, but can't tighten it enough to my liking. Thanks
post #6 of 8 Old 04-05-2011, 06:36 PM
K1W1's Avatar
They don't have to be very tight. I'd back it off by hand and get some thread lock solution on the threads then just tighten it up again by hand and use a spanner to get it a little more secure from there.
K1W1 is offline
post #7 of 8 Old 04-05-2011, 06:42 PM
Load it in the back of the truck , tie it down , then go drop it off at the dealer and let them figure it out.
Don't forget to take lots of pictures then post a write-up for us.
06 DL1000 Red -
"shifts smoother with those mirror extenders!"
00 xr650l -
01 TW200 - resort cruiser
tucsonstrom is offline
post #8 of 8 Old 04-06-2011, 02:23 PM
lthrnckpa's Avatar
Mine would vibrate the nut clean off after about 400-500 miles. And it was a major pain to get my ham-hocked hands into that tiny space. Finally got fed up one day and put a dot of blue locktite on each. Finger tight was good enough, and they have never come off since. Hope I don't ever have to undo them!
Iron Mike - Semper Fidelis
Jack of all trades, Master of none
'04 DL1000 (20,000+ miles)
'11 HD Road Glide Ultra (20,000 miles)
lthrnckpa is offline
