2005 DL1000 with 78k for my first Strom-experience? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Greenstromer
post #1 of 3 Old 06-26-2019, 07:30 PM Thread Starter
Hey all,
I'm keen to buy a Wee-Strom DL1000
This would be my third bike, first Strom.
Planning to go on a trip up North to Canada and back down through the Rockies and across the desert. Myself with my wife as a passenger.
I've found a solid Strom with 78,000 miles, only been on one long trip with the last owner (Second-Owner).
It's been mostly sitting in a garage for the last 2 years, but still in good running order. I've arranged to purchase for $2100. I have a bigger budget, but I'm concerned with resale as it's a 3 month trip before flying out to travel elsewhere.
I think a Vstrom will be the right bike, based on my research and intuition. And I would love to be an active member of the V-Strom cult following
Any advice for me?
Thanks for your help
Greenstromer is offline
post #2 of 3 Old 06-26-2019, 08:43 PM
WildDoktor's Avatar
Welcome to the thought process! Here's my cut/paste when this question is asked:
Things to check before buying...if you don't understand what some of these are, do a search here...they've been talked about a lot. :-)
1. Rotor magnets. If the PO hasn't specifically said he's done the jb weld fix, you'll have to do it. Good indication is if the ad says "new battery"; moved magnets mean the stator doesn't produce enough voltage, so the battery doesn't get charged fully. Also, if a voltmeter on the battery with the bike running at 5k rpm doesn't read between 14v-14.9v, then the bike has electrical issues that a new battery probably won't fix.
2. Stator. As above; if the voltage is low, it's also likely that you need a new stator.
3. Regulator / Rectifier. As above, if voltage is high, you may need a new r/r.
4. Chain and sprockets. Bad chain will cost you a motor. Don't ask why I know!
5. Lowering / raising links. If the bike is too short or too tall, changing the dogbones may be in your future.
6. Deceleration popping. Fix could be anything from an air filter cleaning to re-mapping the aftermarket power commander.
7. Suspension. If it's all original, it probably all needs to be replaced!
7a.Bad steering head bearings - lift the front tire off the ground and gently swing the handle bars past center a few times; if there seems to be a "detent" in the middle, you'll be needing new bearings.
8. Brakes. They're probably due for a flush. Just sayin'.
9. Clutch. If it chatters, it's due for a replacement basket.
10.Farkles - crash bars, skid plate, and luggage. Even if you don't think you need them, it's easier to sell them than to find and buy them!
WildDoktor is offline
post #3 of 3 Old 06-26-2019, 09:44 PM Thread Starter
WildDoktor, thanks for all the advice.
WildDoktor likes this.
