DL 1000 seat hight ( shorter ? person ) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 19 Old 11-20-2017, 02:35 AM Thread Starter
I have been out playing test pilot on a couple of 1000cc V-Stroms today ( and a 650 ) , I am 182cm ( 5'11 I believe ) and due to my body proportions , I am well up on the balls of my feet not quite tiptoe when holding the bike up - ironically I could do with the bars higher up ( long body short legs ) , Is there a solution to this .
The bars there are multiple solutions - it is the seat hight causing my doubts . I have little to no interest in the 650 - I rode the Lams ( Australia ) version , after the 1000 and would not be my first choice .
So what do other short legged people do on the dl 1000 ?
pony-tail is offline
post #2 of 19 Old 11-20-2017, 12:29 PM
Im 58 and with both feet down my toes touch. Usually I just put one foot down. You get used to it... not a big deal. Also, you will learn to be very careful about where you stop... if the ground is too far away for that one foot it can be very embarrassing.. or worse. But again, you learn that lesson pretty quickly too so not a big deal.
Bowtie2bimmer likes this.
Motobillb is offline
post #3 of 19 Old 11-20-2017, 12:53 PM
KKORO's Avatar
There are quite a few after market solutions. I'm 6' with a 32" inseam. When I bought my 2012 V-1000 it came with an after market Seat Concepts seat. I don't know if it's the low seat or not, but I can flat foot it. That was a real plus after riding a KLR with a 37" seat height for the last 3 years.
You didn't mention your inseam, but a Seat Concepts "low" seat could solve your problem. They are quite inexpensive because it comes in a kit and you put it together yourself. Very easy to do.
Much more expensive, but those who have them rave about there merits, a Russel Daylong, I'm sure, would fix you right up.
Be Well, KKORO
KKORO is offline
post #4 of 19 Old 11-20-2017, 01:10 PM
Easy fix , Pony tail . Install inexpensive lowering links (more like "plates" on '14 and up ) and let a reputable upholstery shop shave just a bit of foam off the seat. If they know bikes they can put 2 divots in for butt bones . The stock cover can be used . The side stand will , in my opinion , work better with the lowering links . I think the bike leans over too far when stock . You'll get close to 2 inches lower than stock so you may want a peg lowering kit too. All reasonable and easy. Get that DL1000 . You'll love it.
Allagash likes this.
2014 DL1000 - Sold
2010 Triumph Scrambler- Sold
2014 KLR650 - Sold
2017 Honda CRF250L - current
2016 Honda VFR1200X - current
Slow Eddie is offline
post #5 of 19 Old 11-20-2017, 01:16 PM
Bowtie2bimmer's Avatar
So I don't know what year DL1000 you are looking at but there are a few options:
1) Adapt and overcome. I am 5'8 with a 30 inseam. I tip-toe my 05 DL1000 and have for years. While I have never fallen off, I have had to get off of it to back it into/out of a spot because my toes didn't have the strength/grip/leverage to push the beast.
2)Remove seat bump stops. This is common on the older DL1000, not sure if you can do it on the new ones
3) 650 Seat is shorter (by about .5" than) than 1000 seat. Again, depending on year, swappable
4) Aftermarket seat as mentioned earlier. Expensive, but does work
5)Lower the whole bike
2005 DL1000 - Nadine
2015 Triumph 675 Street Triple R
2007 Honda "Fiddy"
Bowtie2bimmer is offline
post #6 of 19 Old 11-20-2017, 02:23 PM
For the '14 and later DL1000 Suzuki offers accessory seats that are 30mm shorter and 30mm taller than the standard supplied seat. It just so happens that I can flat-foot while on my DL1000's standard seat, but if I needed a shorter(or taller) seating position for sure that would be the route I would take.
As the poster above mentioned, if you do lower the rear, lower the front as well. But then youre dealing with sidestand angle and drivechain geometry. You would also lose ground clearance as well. I would only lower the bike as a last resort.
The Suzuki seats are color-matched to the bike, listed as $235 in their accessory catalog.
MAZ4ME is offline
post #7 of 19 Old 11-20-2017, 04:11 PM Thread Starter
The first bike I was looking at is an '09 the second is a 2010 .
The 650 was a 2012 the seat was fine on it , It was however the Australian "LAMS" learner approved version with cut down power (48 hp)
post #8 of 19 Old 11-20-2017, 04:20 PM
Pony Tail, I didnt know if you were looking at the 650 or the 1000 when I posted. Suzuki lists a + 20mm seat and a -20mm seat for the '12-'16 DL650. Price is $216.
MAZ4ME is offline
post #9 of 19 Old 11-20-2017, 05:33 PM Thread Starter
Sorry about the confusion - I was looking at both .it feels light as after H.D. Tourglide with full ( steel) crash bars and luggage protection ( my current touring bike )
and also my inside leg is 77cm ( about 30.5 inches I believe )
I like the old Harley but as I am getting older , I am finding it a bit heavy on dirt and gravel roads - I do not go "off road " but some Aussie rural area unsurfaced roads are not well maintained . So I am looking for a lighter tourer hence the interest in the DL1000 .
Half the weight of the Harley , similar power decent road manners , and decent dirt road manners and can carry quite a bit of kit all for a reasonable price and pretty good on fuel .
post #10 of 19 Old 11-20-2017, 07:39 PM
Similarly, I was looking for a sport-tourer as a gift to myself for retirement, and was all set on the Yamaha FJR1300. Until I sat on it(no more legroom than my Kawasaki ZRX1100), and 200+ lbs heavier to boot. I came across a left over '14 DL1K...and the rest is history. The best choice I could have made. 1500-mile round trip to Deals Gap and back, was the perfect "dancing partner" the whole way.
MAZ4ME is offline
