Considering a 2007 Wee First Bike - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 14 Old 11-02-2017, 10:21 AM Thread Starter
MapleRoad's Avatar
I've got what looks like a pretty good deal in California about three hours away from me. I'm emailing the owner to ask if he's had a mechanic verify that it's in great shape, if he has oil change records, etc. Is there anything else I should be giving a hard look? Any thoughts on the pricing?
I'm concerned about the relocated starter and kill switch. The pictures show it mounted between the handlebar mounts.
I don't want to be in a hurry to get a bike, and at the same time, I've got an itch to ride.
I'm selling my 07 Vstrom 650 that I've had for the last 3 years.
Mechanically, the bike is in great shape, with approximately 29,000 miles. No leaks or anything that needs immediate attention.
Here's what's been done:
New fork tubes + seals
New Front and rear brake pads
New front brake rotors
V-stream tall touring windshield added
Heated grips with 5-level controller
Faulty ignition button bypassed (a known issue with these bikes)
55w Hi-output halogen headlights
New chain+sprockets
Also, the bike will come with mounting brackets and ammo-can saddlebags, magnetic Joe Rocket tank bag, plus a few other extras.
Cosmetically, the bike is a little rough, but is ready to ride and has plenty of life left. Motor is in great shape and was owned by an older, experienced rider before I bought it and continued to keep up on regular oil changes. Hate to sell the bike, but I've decided that I want a quad instead. $2800 obo.
Thanks for looking
Thank you for the help!
MapleRoad is offline
post #2 of 14 Old 11-02-2017, 10:27 AM
Perhaps you could ask if a fellow member of the forum would be grand enough to stop by the location and give you a report of what they find you may be less concerned.
You don't mention the general location of the bike. Some may be willing to take a peak.
Old Time Rider likes this.
post #3 of 14 Old 11-02-2017, 10:35 AM
I wonder if the bike has been crashed. Changing the fork seals and tubes may indicate that unless the tubes were neglected and rusted, then ate the seals. There is an issue with the headlight cutout section of the start switch, but the fix would be to clean and adjust the contacts and add headlight relays. Relocating the switch is odd. See if the headlights go out when pushing the start switch. If not, that feature was bypassed. New front rotors could indicate the brake pads went down to nothing and scored the rotors. A bike with that mileage should not have rotor problems. The stock headlights are 55W low beams and have excellent lamps. Replacing them will shorten their life. It sounds like he had headlight issues, which is not uncommon, and chose a poor fix instead of the proper fix of repairing the switch and installing headlight relays.
https://www.stromtrooper.com/informat...-problems.html
https://blacklabadventures.com/2012/...h-maintenance/
post #4 of 14 Old 11-02-2017, 10:44 AM
rwbandler's Avatar
I would be patient. IMO, that is a bit high for the mileage and condition. A few years ago I paid less than that for an '07 with 14k miles that was showroom condition.
In my experience (5 VStroms) the "ignition button" is not a problem area. I assume he means the starter button on the right grip.
It is a great suggestion to have a forum member inspect a bike for you or with you.
Rob
rwbandler is offline
post #5 of 14 Old 11-02-2017, 11:15 AM
Cash is king right now.With way too many bikes last Dec. I did the smart thing and bought two more used ones just because I had two like them and thought they were way too cheap. The market IMO is more down than way back in the early 80s. One of the two I got was a one owner 09 650 Wee for $2,700. His knees had got bad and at 68 was a little younger than me. He had traded it in to a local dealer for a Burgman.I had bought lots of bikes from this dealer.
Had good every thing,looked like new, with center stand,skid plate,side bars,taller Giv. shield. nice soft side bags. Only 26,000 and that was less than half my 011 got new in 012. I see them as cheap often since then. Look around good before laying money down.This one came down from $3,900! Good luck,they are so great little motorcycles.
Old Time Rider is offline
post #6 of 14 Old 11-02-2017, 11:49 PM
dmfdmf's Avatar
You can do better. It sounds sketchy to me. What GW says about the front rotors: should not need replacement at 29K miles. My 2007 is at 95K miles and rotors are still within spec. Headlight/starter fix is a kludge and would have to be redone, hopefully he didn't hack the harness to "fix" it nor to install the halogen lights. If you are itching to ride low-ball him at $1000, I wouldn't go much higher than that.
I am in San Mateo, PM me to connect and I can show you my 2007DL650A and what to look for on a used bike.
Big B likes this.
Next Up: ?
dmfdmf is offline
post #7 of 14 Old 11-03-2017, 01:52 PM Thread Starter
MapleRoad's Avatar
My previous reply must stuck in moderation. Thanks a lot to everyone in this thread. I'm so impressed that I bought a premium membership.
Big B likes this.
post #8 of 14 Old 11-03-2017, 04:09 PM
Macdoc's Avatar
OP ...this is your first bike?? What is your inseam??
Vstroms can be a handful as a first ride ( hell anytime with short legs )
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
post #9 of 14 Old 11-03-2017, 04:39 PM
Stromtrooper.com Sponsor
Satch's Avatar
He bought a premium membership here so it sounds like he's committed regardless of inseam or experience.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #10 of 14 Old 11-03-2017, 05:15 PM Thread Starter
MapleRoad's Avatar
Yes, this is my first bike. Even if I don't go with a DL650, the folks here have already given me advice worth 50x the membership cost.
Inseam is 34", and I weigh 230lbs / 104kg. I've passed the MSF, received my M1, and I've been allowed to sit on a V Strom 1000 at the dealership. I was comfortable in the saddle, got both feet down, and the ergonomics seemed pretty good. I'm looking at a used 650 that I can try out, get used to, drop a few times (I'm told we all do), without having my wallet cry.
Big B likes this.
