In HOUSTON TX - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-03-2009, 01:10 AM Thread Starter
In HOUSTON TX
I was thinking about getting a V-strom 650 as a main mode of transportation. I love motorcycles and started out with a naked SV650, I loved it. I found a 2008 for a sweet price, the dealer doesn't slip in hidden fees either.
My question is:
Do you believe I can ride this bike to work/school year round with the right gear aside from the rare hurricane or tornado.
I want to ride 2 up with my wife she is 130lbs but I am 270lbs, is that just too much weight?
How much money should I expect to put out a year in maintenance? I live in an apartment so I will be limited in fixing anything serious.
Thanks in advance
HoustonTX_Rider is offline
post #2 of 6 Old 05-03-2009, 03:30 AM
chris swann's Avatar
v strom
the load limit on a v strom is 500 lbs , so you would be 100 lbs under with the wife on the back , the first two years of ownership only cost a couple of oil changes . the third year would be a back tire and some spark plugs and radiator fluid + some brake fluid .
swann strom
chris swann is offline
post #3 of 6 Old 05-03-2009, 12:49 PM
Any thoughts on UV protection? FWIW, there's some discussion in the linked thread...
https://www.stromtrooper.com/showthre...t=38879&page=2
04 DL650, 18k+ miles, lowered, grip heaters, hand guards, touring laminar lip, trunk, soft saddlebags (when needed), aprillia mirrors, frame&swingarm sliders, fork brace, skid plate
re-psycle is offline
post #4 of 6 Old 05-03-2009, 08:44 PM Thread Starter
What about valve or cam adjustments?
post #5 of 6 Old 05-04-2009, 02:23 AM
Austin44's Avatar
Valve check about 15,000 miles. How soon depends on how many miles you ride each year.
My K2 just turned 20,000 and I finally did the first check. All were barely OK at the low end of
the clearance range. I'm changing shims to put them middle-to-high end of the range. My
dealer wanted $220 plus cost of parts to do the job. YMMV.
Per posts on this and other forums, this may only have to be done once. Re-checking at 30k
and 40k shows little change on many bikes. Evidently, the initial wear is by far the greatest.
I don't believe you can beat a V-Strom for reliability.
Austin
Austin44 is offline
post #6 of 6 Old 05-04-2009, 02:31 PM
prothos's Avatar
I live in Hoston and ride my Wee prety much year round. I do not ride if its pouring rain or very high chance of rain as the Houston drives cant drive in rain so i don't want the added risk. I have had My bike for a little over a year and put about 11k on it. I have replaced both tires once, changed the oil about 4 times, checked the air filter and plugs both still looked clean so i elected not to replace them when i looked at them at 8k. I will replace airfilter at my next oil change though. I'm 245 and the wife is not as small as yours and the wee suites us just fine.
Flat Black Club Member # 29
2008 Suzuki DL 650 V-Strom
prothos is offline
