Little fat man on a wee? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Maddy
post #1 of 8 Old 03-24-2016, 07:28 PM Thread Starter
I'm curious as to what the forks/shocks are rated for on the wee. I'm 5'7" around 265 lbs. and roll down hill when pushed. With gear I'll probably be +15-20 lbs. and occasionally loading 30-40lbs of gear. Will I need to respring or rebuild suspension components?
Maddy is offline
post #2 of 8 Old 03-24-2016, 08:28 PM
strominateacup's Avatar
Probably not, I'm 85kg (OK, 187lb) and sometimes ride with my gf, it handles two-up fine with the rear preload wound up, I've never adjusted the forks.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #3 of 8 Old 03-24-2016, 09:09 PM
I agree with Teacup. My wife and I together are about 300 pounds, plus luggage and whatever. Never a problem. At least if you fall, you can just roll away! (per your description)
bobbyvstrom is offline
post #4 of 8 Old 03-24-2016, 10:52 PM Thread Starter
Awesome, that was one of my biggest concerns. I'm a lot like a pill bug, I just curl up and roll.
bobbyvstrom likes this.
Maddy is offline
post #5 of 8 Old 03-25-2016, 11:24 PM
If you don't have a long inseam, you might want to lower the bike and seat some for more slow speed and stopped stability. Sure helped me. Bobby
post #6 of 8 Old 03-26-2016, 02:20 AM Thread Starter
With a 28 1/2" inseam almost every bike is to tall for me hahaha. My DRZ was hysterical with a 35" seat height. My concours was 32" and a lot wider than the wee I may end up opting for a low seat, but I won't do lowering links or anything.
Maddy is offline
post #7 of 8 Old 03-26-2016, 11:51 PM
The 650 seat is lower than the 1000 one. And you can take the rubber bumpers out from the bottom of the seat for 1/2 inch gain. Unless you are going off-road with it, lowering the bike is just fine. Just do it front and back. Takes about an hour. Lowering links on the back and sliding the fork tubes up through the triples in the front. Handlebar risers make it possible to lower the front 1.5", same as one might do the back. Bike is level and handles great.
post #8 of 8 Old 04-05-2016, 10:12 AM
Its really nice to know that there are more of us out there, you just described me. I've never done anything to my suspension, and don't feel it's necessary.
Pharmrider is offline
