How many miles are too many miles?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 03-26-2015, 09:07 PM Thread Starter
Mexicant's Avatar
Assuming all the maintenance is up to date etc and there's records of it, how many miles would you not be too worried about? There's an 07 650 that I kinda want to go look at on Craigslist but it has 112k miles. Would that be too many miles to even consider?
Mexicant is offline
post #2 of 11 Old 03-26-2015, 09:25 PM
These bikes and engines are hard to kill, as long as a good deal is given......go for it!!!!
post #3 of 11 Old 03-26-2015, 10:46 PM
At 112K miles I'd stay away.
Yes, there are probably more miles to be had, but way too many bikes / opportunities with far, far fewer miles.
For me, 112K is too many miles. Especially for a Wee.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 44K+. Love it!
HokiesRWee is offline
post #4 of 11 Old 03-26-2015, 10:53 PM
If the price is right and it appears and feels like it's not worn sloppy, you could give it a go. It is a lot of miles. With our de-tuned engines, the running gear lasts a long time. I'd be more concerned with things like wheel bearings and head bearings, swing arm bushings and like that. If it's tight, why not go for it?
bobbyvstrom is offline
post #5 of 11 Old 03-26-2015, 11:20 PM Thread Starter
Mexicant's Avatar
I talked with the guy and he's firm on $2k for it. Not sure since I see a few 650's for around $4k with under 20k miles and some farkles...
Mexicant is offline
post #6 of 11 Old 03-26-2015, 11:39 PM
tenny80's Avatar
I'd stay away unless you can do all your own repairs
2018 Vstrom 1000
tenny80 is offline
post #7 of 11 Old 03-27-2015, 10:01 AM
Yep. My point exactly. At 112K there's got to be wear everywhere - as someone else mentioned - not just in the engine.
$2K is way too much for those miles. If it was a free or nearly free (say $500) opportunity (the guy just wanted rid of it) and you had the time and ability to completely go through the bike (maybe not the engine though), replacing worn parts as you go, maybe that's OK. That would be sort-of a personal-challenge sort of thing. But most guys, myself included, don't want to do all that.
post #8 of 11 Old 03-27-2015, 02:32 PM
All the bearings & bushings in the swing arm assembly are a lot of work. If the shock is original, it's overdue. Ditto for fork bushings. Probably ditto for the steering stem bearings. Wheel & sprocket carrier bearings. Clutch. The engine and probably the transmission will likely be OK. Everything else can be a project. $2k if you're handy with wrenches might be OK. Not if you have to have a shop do the work.
post #9 of 11 Old 03-28-2015, 07:01 PM
randyo's Avatar
that all depends on how the previous owner(s) kept up replacing worn parts
for instance, my SV650, in 135k, I replaced the levers & perches a few times just cause they were sloppy, same with shift linkage, steerng stem bearing , also replaced calipers rather than rebuilding them, @ 135k, with the exception of rear shock, everything is as tight as a bike with less than 20k
things to look for
1. levers.. is there slop up and down
2. shift linkage, how much slop, does it bind?
all parts are replaceable, just be aware of what needs to be replaced
$2k sounds steep, but not if those things have been replaced (I would look for professional service record, on my SV, my dealer could supply me with nearly 100 pages of service records and milage that parts were replaced)
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #10 of 11 Old 03-29-2015, 04:26 AM
Forget about it. Let him have it with his $2000 firm. Spend another $2000 and get yourself newer ABS model with low mileage. Or perhaps for about $3000 you can get no ABS one with way lower mileage.
Rick123 is offline
