What OCTANE fuel do you use? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-24-2008, 05:59 AM Thread Starter
angstrom's Avatar
Question What OCTANE fuel do you use?
Hello Troopers,
Long-time lurker, first time post...
I'm dropping into a new, '08 Wee today and want to squeeze all the value from this tremendous bike.
Along those lines, what octane rating do you chose when you fuel your v-stroms? 85? 87? 91? Those are my choices, and I'd like to understand what the sweet spot is for vehicle performance, fuel efficiency and reliability.
Sadly, I'm undereducated with respect to octane and its impact on the above, so your advice is much appreciated!
angstrom is offline
post #2 of 13 Old 04-24-2008, 06:57 AM
K1W1's Avatar
The great thing about the Wee is that it runs on almost anything.
When you read your owners manual you will see a list from Suzuki that includes ethanol blends and all sorts of octanes.
Basically run it on the cheapest fuel you can get you will notice no difference in performance or reliability compared to running on higher octanes.
K1W1 is offline
post #3 of 13 Old 04-24-2008, 07:48 AM
You want to run 87 about 90% of the time, you might consider 89 when it gets REALLY HOT/humid out.
post #4 of 13 Old 04-24-2008, 09:59 AM
If 85 is available in your area, it is the regular grade for your altitude. It will be fine unless you ride down to lower altitudes. The manual's 87 rating assumes lower altitudes. Octane ratings are often misunderstood. As long as the engine is not pinging, there is absolutely no benefit to running a higher octane fuel. If the engine starts making noises like it's shaking a tin can full of BBs, most likely when applying a lot of throttle while running fairly low rpms, then and only then will an octane boost help.
post #5 of 13 Old 04-24-2008, 10:15 AM
SVDon's Avatar
Your engine is built to run on regular grade gasoline. If you are at an altitude where 85 octane is offered, that's regular in your area.
The only benefit you'll get out of running premium is that your bike may handle better in the twisties due to a lower total weight, because you won't have all that extra money in your wallet.
Actually, running premium in an engine designed for regular may, in fact, reduce power and lower your fuel economy slightly. There is no advantage to running a higher octane.
Always run what's recommended in your owners manual, on any bike.
Don F.
Smith, Nevada, In view of the High Sierra
DL650 K4
DL1000 K5
Keeper of the ST1100 liST [url]www.st-riders.net[/url]
[url]www.quilt-kits-online.com[/url] for great quilt kits and supplies, outstanding customer service.
SVDon is offline
post #6 of 13 Old 04-24-2008, 10:24 AM
Chimone's Avatar
87 octane 100% of the time
2008 VStrom DL1000
2008 VStrom DL650 ABS #09 -Gone but not Forgotten-
Chimone is offline
post #7 of 13 Old 04-24-2008, 10:31 AM
The thread title may be a bit misleading. What you want to know is what octane to use in your bike. All we flatlanders need a higher octane than you do. I use 87 around home but 85 when I ride in the mountains.
post #8 of 13 Old 04-24-2008, 11:01 AM Thread Starter
angstrom's Avatar
Very informative! Since I do live in Colorful Colorado, it sounds like 85 is the choice for me. That's a relief!
Thanks y'all. I really appreciate the prompt replies, and I look forward to learning more from this great website!
angstrom is offline
post #9 of 13 Old 05-03-2008, 11:30 PM
jwt
jwt's Avatar
I have a 650, and I tried premium two different times and noticed zero difference. So what I do is fill up w/ regular and pour a couple of ounces of lucas fuel treatment in each tank. I fell in love w/ this product after using it in my twin cyl. Kawasaki walk behind mowers. If you haven't tried this product, I don't think you'd be disappointed. It's totally different than every other product I've tried, it increases my mileage and has kept my motors amazingly clean internally. Just check out the viscosity of this stuff, it's pretty amazing for a fuel treatment. By the way, I don't work for lucas, I am merely a concerned sports fan.
"I believe the most damning thing that can be said about muslims is saying you're afraid to say anything."--Penn Jillette
Pointless Profanity Club member #10 ****face.
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
jwt is offline
post #10 of 13 Old 08-15-2008, 10:38 AM
octane
Octane as an additive slows down the propogation of the flame front, and resists auto-ignition.
A higher octane #, is usually necessary in longer stroke engines.
Not always, as other design factors can come into play.
Choose your octane grade fuel based on being the minimum grade prior to "pinging". As you see, weather ,altitude, load , and operating habits, enter into the picture also.
It is true that higher octane #'s not needed, is a waste of money! USUALLY !
That said, most oil companies also introduce quality additives at the mid-grade levels. i.e. cleansers, upper cyl lub, anti rust, etc, that you do not get at in the low[est] grade, as part of their additive package.
Mid-grades will usually get you that "package" minus some octane.
Example:
I've got a guzzi that has "expensive tastes", a Honda ST11 that just does not care, and a BMW 1150 that runs well on puke gas only most of the time except for mid-summer..
ride safe, have fun
roadancer
roadancer is offline
