Power Draw. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-14-2008, 06:28 PM Thread Starter
Power Draw.
Not being an electrical genius has a few drawbacks. Question for those who know more than I do. Have two 50 watt bulbs wired in parallel , power draw is 100 watts total, got that figured out. Wiring the two bulbs in series.........is the power draw still 100 watts total ??? I am sure I knew the answer to this 40 years ago but the mental filing system is rusting out.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 6 Old 03-14-2008, 07:08 PM
In series, two 50W bulbs would draw 25W and be very dim.
post #3 of 6 Old 03-14-2008, 10:30 PM Thread Starter
I will assume 25 watts per bulb and that is just perfect for my purposes. Have two driving lights with MR-16 bulbs that I want to use for more visibility to oncoming traffic. They are yellow like my last ones. Wired in series as an experiment they are very noticeable without being blinding. Wired in parallel will make enemies very quickly. Thanks a bunch GW. Much appreciated.
05 / 650 in blue
75/Suzuki 125 RV
post #4 of 6 Old 03-15-2008, 01:17 AM
I was a bit glib. It's actually more complex than that as each bulb gets 6V in a 12V series circuit. Rated wattage is targeted for the rated voltage. The filaments don't get as hot with the lower voltage so their resistance is less and power draw more. Still. The total power draw will be way less than in parallel.
post #5 of 6 Old 03-15-2008, 06:07 AM
msi1259's Avatar
You may get more light if you changed the MR16 lamps from two 50W in series (~25W) to two 10W bulbs connected in parallel (20W) due to the above point.
DL1000K5
msi1259 is offline
post #6 of 6 Old 03-15-2008, 07:24 AM Thread Starter
Yup, that will be my next option if I have a dead battery one fine day. I do want to try the present bulbs because of the color which is very eye catching. 10 or 20 watt MR-16 bulbs are very common but none that are yellow. What would I do without a little technical adventure and little to no knowledge on the subject ?? LOL................At least others can be entertained with my mistakes and misadventures.
05 / 650 in blue
75/Suzuki 125 RV
