100K too many miles?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-09-2013, 03:28 PM Thread Starter
I'm looking at a 2005 with 100K miles. Probably burns oil. Should I run away?
What would the value of something like that be? I found a couple used motors on Fleabay for about $1300.....
I'm thinking the value (having to replace the engine) would be somewhere in the $1,000 area... thoughts?
desert_rider is offline
post #2 of 6 Old 09-09-2013, 03:49 PM
Texas Oilman's Avatar
"Probably burns oil"? Does it smoke or no?
https://www.stromtrooper.com/dl-1000-...e-writeup.html
Read up sir, these bikes are built to last. I wouldn't think a new motor would be in order unless major damage has been caused.
Texas Oilman is offline
post #3 of 6 Old 09-09-2013, 04:46 PM
First off a 2005 what? 650 or 1000?
Does it have any service records? What maintenance is done or not.
Theres a lot more to it than an engine, but a compression and leakdown test would tell you a lot.
Personally I don't screw around with high mileage bikes like that. I don't see the point as you can usually find low milers for not that much more and I want to ride on them, not work on them.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #4 of 6 Old 09-09-2013, 06:04 PM
568v8's Avatar
no oil
My 2007 Vee with 130,000 burns no oil and runs as well as when it was new. No breakdowns, no hiccups, no hesitation ever at sea level and 12,000ft and lots of places in between. Totally reliable and the performance has been flawless.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #5 of 6 Old 09-09-2013, 06:15 PM Thread Starter
I haven't seen it yet - been emailing back and forth with the owner. He lives an hour away. He said to someone else that it does burn a significant amount of oil. So I was figuring the price of another used 10,000 mile motor into the purchase price to figure what I thought it might be worth.
post #6 of 6 Old 09-09-2013, 06:16 PM Thread Starter
There are several used motors on Ebay for about $1,200. Each with roughly 10K miles. I'm assuming anything between 2004 and 2009 would be a direct bolt-in?
