I have a Zumo 450 and use it as an MP3 player ( connected to an audio amplifier ) and have a question. I load my SD card with about 600 MP3 files and I can listen to them as I ride, only problem is it takes about ten minutes for the files to be read. So for the first 10 miles I can't play them on the Zumo. Is there a trick to loading my SD card? Should I use folder and sub folders or what is the best way to handle this problem? Thanks.
That's it. I have my files structured by albums. Also, the 450 and 550 have a limit of 1000 songs. I've stitched the songs together in some albums using Direct MP3 Joiner so they appear as a single MP3 file. I have well over 1000 songs in 72 subfolders and they take less than a minute to load. The Zumo thinks I have about 600 songs. It does take a couple of hours to play the compilation title in a Beatles album though.
Greywolf, I got daring and went right ahead and made ten folders of 100 files each. I turned the Zumo on and right away the Zumo showed all 1000 songs in the menu but I couldn't play them. Usually when I see the counter ( 31/805 etc. ) the Zumo will play. This time it didn't. I then just loaded five folders of 100 each, I also put two seperate files outside the folders for a root file. Now it works fine. I will experiment more ways of doing this. What a pain everytime I want to take the SD card out....have to remove that stupid slotted screw. On my Goldwing I have a J & M mp3 player mounted in my trunk and it has a USB cord extension that I use to connect jump drives to. It's real easy, I just stop somewhere and unplug the drive from the USB, insert another and on my way.
Right now I record a bunch of podcasts from NPR in iTunes, then copy them to a playlist, them clipboard the playlist onto a memory card. There must be software that would do this directly with an MP3 player other than an iPod.
Most of my stuff was originally CD tracks saved as .wav files and converted to MP3 with Media Player. I also have radio, cassette and TV audio recorded through the analog input on sound cards. Early on, the input was saved as .wav files with a Creative Live sound card. Lately, I use the Windows 7 sound recorder to record .wma files. Then I use a Jodix.com converter to turn the .wma files to MP3.
