1 - 20 of 33 Posts
I felt something a bit graunchy on my rear brake today and to my surprise the rear pad was completely worn out and rubbing metal to metal. :jawdrop: I was very surprised as I changed the rear pads for the first time not so long ago.
I use a lot of engine braking and I still have the original pads on the front after 30,000 miles. I don't ride the rear brake or anything and I though I was fairly light with it as I always brake harder with the front wheel.
Anyone else notice this fast wear rate? Unfortunately I didn't record the milage when I changed the rear pads but it can't have been more than 10,000 miles ago. I am pretty sure I got EBC organic pads for the back the last time. Are these reputed to wear quickly?
cheersr
I tried one set of EBC organic pads on the rear of my 1k a few years back. They were gone in about a month. They probably would have last a little bit longer but getting the back end stuck in a wet clay hole finished them off real quick. I went back to the EBC HH pads, and even then I change them out when I get a new rear tire. But I admit I use the rear brake a lot.
Stop riding with your foot on the rear brake pedal ?.
You can also adjust it so it engages lower down which may help.
Pete
Be VERY sure of that, it's the most likely cause.
Plan-B is pull the pads out, scrub everything inside the calliper down with methylated spirits, make sure there's no grit stuck in the piston and reassemble. A THIN smear of brake grease on the pin is a good idea unless you ride in sand a lot.
Check the level of fluid in the rear brake reseviour, make sure some kind mechanic didn't top it up when the pads were worn so it's overfull with new pads.
Use the front brake as Suzuki intended ;).
Cheers
Pete
It's quite possible that the brake is misadjusted. I had that problem on one bike when moving the pedal because I lowered the peg.
A slight bit of friction can really wear them out quickly.
Some after market pads wear more quickly than factory too.
A grease fitting at the rear brake lever pivot point would be a good thing too. The rear brake of my bike was dragging at that point during winter a year or two ago. A difficult-to-lube point if a fitting's not there.
Yup, I found the rear brake wear much faster than I would reasonably suspect given my braking patterns.
Also for general reference, EBC HH pads are too strong - they lock up the wheel too easily.
I have like 34,000 miles on my rear pads, must be doing something wrong. The fronts have been replaced once I think around 25K, they look brand new still.
I think the key is pad quality and lubing the slide pins, I don't run nothing but OEM till I replace them with DP usually or OEM if I can't wait for an internet order. Every time I've had to get EBC HH I end up changing the noisy suckers out. DP pads are like stock with more longevity and they run much cleaner, no black crap running everywhere from them getting wet. But, DP can cost more than OEM sometimes...
I use my brakes together often and drag my rear in the mountains too, don't baby them at all. Engine braking is my savior of brakes probably, I keep revs up and like my curves under power. My FJR went about 30K before needing pads, tires lasted about 4,500 though. My DR650 needed pads every 10K or so because of the dirt roads...
I too wear rear brakes first. probably cause I don't use brakes much, I just roll off throttle and when I do use brakes, it's most often for low speed maneuvering
Yup, me, too.
Thought that was all due to the car tyre on the rear ?. :)
I'm getting about twice the life on the rear that I do on the front, but I do strip the callipers down and clean them out every 3-6 months.
Around 68,000k's, on my 4th set of front pads, second set of rears . With really good front brakes I get a lot less rear wear, which makes sense. But 1 month unless it was all riding seems really short.
Pete
Most of the time if you have accelerated rear brake pad wear and it's not a mechanical or environmental related (mudholes and whatnot) issue it's due to overuse of the rear brake during normal braking.
Maybe the rear wears faster because there is one rotor instead of two. It could be carrying a proportionately higher load. That and the fact your legs are stronger than fingers so you may be braking harder than you think. Just a guess but it seems quite possible to me.
OR..
Or maybe your foot is resting a little too hard on the brake lever. Check your rotor temperate when you get off the bike - is it hot every time? IF yes, then - you are dragging the brake subconsciously.
I was !!
I replaced my rear pads at 29K miles, and they look like they will need replacing again soon, I am only at 40K now. I replaced with organic pads last time but will be going to the HH's this time. Still plenty of pad left on the original front.
I've always worn the rear first, ever since I've had bikes with phenomenal engine braking, first, with my SV650, now with my Vee
I really only use brakes the last few feet rolling to a stop after I disengage the clutch, 99% of my braking is just rolling off the throttle
I use brakes most often for low speed maneuvering when I am also slipping clutch and feathering throttle
the rear brakes on my Vee lasted about 50k, at 80k, I still have the original fronts
Discussion Starter #19
Btw I am loving the HH on the rear. I don't find it harsh at all and I don't think the ABS has kicked in once yet despite all the ice and snow.
At 16k miles, my rear break pads are toast. I am not going to wait until I hear metal to metal to swap them, but I can already feel deteriorated performance from the rear and see almost no meat left on the pad. At first I was ticked, but then I remembered that my Victory Hammer burned it's pads up by 6k miles, so 16k on the vstrom is actually not so bad, lol!
1 - 20 of 33 Posts
