Check your kill switch
Check that your key is turned on
Pull in your clutch and attempt to start.
Doesn't work?
Check your side stand switch--wires intact? attached properly?
Check your clutch switch--wires intact? attached properly?
Still won't start?
Did your clock re-set to 1:00?
If so, you have low battery voltage...check it with a meter.
You can charge your battery, jump it with another 12v vehicle (not started is best). What is the voltage when the bike is running? Does it increase when the engine is rev'ed?
That's a good start...
...well, with luck...
Doesn't work?
Still won't start?
