Since you installed the fuse block, I assume you're planning to connect other electrical accessories in addition to the lights. The lights need their own relay, otherwise all the current they draw will travel through the switch, which probably wasn't designed for that. It sounds like your lights didn't come with a wiring kit. If not, you can get a very high-quality one from Eastern Beaver. Jim the owner is a fellow Stromtrooper and Strom rider, and he also sells a number of Strom-specific kits.
