1 - 15 of 15 Posts
So I am 6'6 and I already have a tall windscreen and the buffeting and wind noise in my forehead vents is real bad. I started looking at options. While I am sure the Madstad is great, at over $200 I can't afford that right now. I then saw the MRA spoilers but again at $130-140 for a small chunk of clear plastic and some hardware I about lost my mind. That's when I stumbled upon this, the Motoparty windscreen. Its a direct copy of the MRA and it ships from China via Amazon. Its $35 shipped. The first big deal was the MRA gets bad reviews because it doesn't include instructions or come assembled. The Motoparty comes also without instructions, however its assembled ready to install. It feels very high quality and very solid. When you throw the locking levers it doesn't budge. On the highway it doesnt flap or vibrate, it just does what its supposed to. I have it set to be just under eye level while cruising and I am sure I will tweak/experiment over the next few weeks, but its solving all my problems, much less wind noise, no buffeting, I can ride at 60MPH with my visor open and its comfortable. Highly recommended.
The Givi Airflow is the best screen I have had on a strom. But it doesn't fall in your budget - unless someone has a used one you could buy.
Honestly this thing works so good I am not looking for anything else anymore.
I think the reason the Givi screen works is it kind of wedges the air and speeds it up.
You maybe able to achieve something similar with that screen if you play around with it.
You could then have the screen lower but still have the air travel over the top. ??
I love it when people think outside the box, nobody wants to pay for a Givi but there is no doubt they work.
I have used a MRA spoiler on a different bike and the MRA XC Multi-X-Creen windshield on my DL and liked both a lot. I like the adjustability, could raise it when its cold, lower when warm and tilt it back to get more air flow across my helmet shield when its raining.
The MRA XC Multi-X-Creen windshield was damaged in a crash so I'm going to use the stock windshield and I recently ordered the Amazon spoiler, nice to see a good review on it.
I've been pretty interested in trying out one of these extensions. My bike is a little unique though. The front end of my V-Strom is quite unlike any other.
Still, I'd like the opinion of folks who have tried them. My current windshield comes high enough that it requires good posture for me to see over it. If I add a spoiler, I would think I would need to cut the screen down a bit, which is no big deal. I've cut numerous screens, including this one. So, the question: what is the difference in height from the top of your screen to the top of spoiler in your high speed, long day position? Can you JUST see over the spoiler? Or easily see over it? Thanks for any help.
thanks delasangre for this review. I too was looking at that same extension. Two things I like was that it didn't "appear" to have the rounded lip around the edge that I saw on others. I also saw there are two different sizes...did you get the slightly larger one?
I'm tall enough that even with the spoiler up a few inches I'm where you are now, with good posture I'm looking at the road in front and with a slouch it's right on the horizon looking forward. But at that level the wind protection is stellar. I think you could run this flush with the top of your existing windshield and still get the reduction in wind. I'll take some pictures to show the range later.
I went for the smaller one. Look at the specs they provide for the distance between mounting points and go measure your windshield. I found the big one wouldn't have even been close.
I have a similar air foil deflector which I bought from China for about $25 on my 2018 DL1000 using a Puig windshield. The air foil deflector works great. I tried adjusting the angle and position, but there doesn't seem to be any real sweet spot- it seems to work pretty good with any reasonable angle/height adjustment.
Holding my hand up to feel the air flow with the air foil, I can feel air coming from two streams- one stream is from the large windshield and another air stream is from the smaller deflector. Together, these two air streams result in less overall the pulsing air turbulence which causes the buffeting.
For the guys wondering if these small deflectors actually work, I'd say yeah, go order one. It's not a big expense and I think you'll be happy.
Reasonable and realistic review and advice! Thanks.
The Wee I got had the MRA Vario shield on it when I bought it. Very happy with that and replaced it after a crash that broke it.
I got another Wee and bought a used MRA Vario from a fellow member for a good price. So I'm set if I ever get it going.
My BMW has a cut down 25" CalSci and Laminar lip on top of that. Yep, it's amazing what a simple piece of plastic can cost. But the makers have figured out what shapes need to be and saves you endless testing on your own. That alone is worth a big Thank You to the vendors!
Oh, yeah and watch the for sale sections here and ADV site.:fineprint:
1 - 15 of 15 Posts
