I had to replace a broken windscreen bracket, and some of the fittings got tossed by the accident. The new bracket didn't come with the fittings.
I can't find them in any Suzuki parts catalog and need part numbers. The parts house I use doesn't know and is researching. I need some soon!
Specifically, I need the nut-backed rubber windscreen mounting grommets that are attached to the holes in the mounting bracket that the windscreen screws drive into.
These:
Better yet, if anyone has 4 they'd like to sell, I'm a buyer!
TIA
Robert
TC, thanks for the response.:thumbup:
But I'm still a little confused. On the parts fiche the #8 screw/washers are what screws the windscreen into that rubber nut thingy attached into the windscreen brace. The part you suggest has the #9 screw/washer going into it, and doesn't appear in the fiche to be going through the windscreen. In fact, I'm not sure what it even does.
Am I missing something?:confused:
What say you?
Interesting lesson. I found they're called well nuts. They come like this:
They deform after three years into this:
When they arrived I thought they were the wrong part, but they work just fine.
Thanks for the help, guys!
I think the "deformity" is actually just the swelling up that is designed to do that to hold the screen in place. I some trouble with my Madstad bracket as I didn't tighten those screws enough to get it swelled right.
Are you sure its the same part?
dont you mean #10 NUT 09159-05019 instead of #6 NUT 94619-36A00
it looks like number 6 is for the fairing not the windshield bracket.
I also bought a replacement rubber well nuts and the windshield fell off it seems like the well nuts wot stay in the bracket
i lost my mind thinking iam doing it wrong until i saw the original part have a small bump and that bump grips it in place.
did you succeed in mounting the windshield with the nuts without the bumps?
i would appreciate it if maybe you could post how you did it, and i still cant find the original nuts with the bumps,
help plzzzzzz!
Naor dl-650 k7
added some pictures with the part i found SD card for scale
