'05 DL650. I've noticed that used SV650 rims sell for half that of used DL650 ones- maybe because there is a large supply of them. A parts search shows that the part numbers for the rim and rotor are different between the models, but that could simply be a color variation. I like having an extra wheel with a new tire pre-mounted and balanced so that a tire change can be made quickly, and the old tire can be dismounted from the swapped-out rim at my leisure. Is it a direct fit?
I believe the SV650 rim fits a 160 tire where the V fits a 150.. I'd think the sv650 rim will not fit, may be wider?...
I don't know if this helps you out but I believe the 650 Bandit uses the same rim. I can tell you for sure tomorrow. I have one in the shop that I just put a set of tires on.
Discussion Starter · #5 ·
Thanks. As a daily MC commuter I like to minimize downtime by having a fresh tire ready to go, preferably on a full setup with sprocket and rotor already attached.
