From what I could find, it states they are no longer made by Suzuki. There seems to be a few on ebay, Google the part number. 56221-27E00.
Good luck
Good luck
The riser on this bike mounts in rubber so I am a bit surprised it is causing your issue. I raced bikes for years as well as owning a OEM motorcycle shop and seen more out of aligned handlebars than I could count but I can't recall ever seeing that particular part being damaged. I have seen MANY bent handlebars as well as many forks twisted in the triple clamps. Are you certain this part is the cause of your bars being a bit off?
It's entirerly possible that the handlebars are bent as well, but when I bent down to look at it from the side, the number 14 part looked bent forward to me from that angle. If those don't bend then maybe that long bolt 15 that holds it on did.The offset risers that he has in that picture may have provided enough leverage to bend the bolt. Although I doubt that the riser itself is bent. Easiest way to figure it out is take a few minutes, take it apart and lay everything on a flat bench.
Could be the camera effect, but those mounts/the bar doesn't quite look parallel to me.Need a bigger pipe, but it looks like it ain't the handle bars that got bent
