I noticed today that even though they are tight, both my front caliper bleed valves have significantly more thread showing that the rear one. Is this normal? Is there a reason for them to have so much more thread exposed?
Maybe a previous owner installed speed bleeders.
That's normal. Someone can correct me if I'm wrong but I believe it's a tapered fitting that's how they get the seal without any form of washer or gaskets. The front bleeders are a tad on the long side but if they aren't leaking it's nothing to worry about. My DL1000 front bleeders look exactly like yours.
The bottom seals the bleed hole. The length of exposed thread doesn't matter.
Probably to reduce manufacturing costs. One long bleeder screw will fit many different style calipers.
None issue.
