1 - 20 of 34 Posts
I have been running a set of Mitas E07 Dakars for nearly 7500 miles, and still plenty of tread, the longest a set of MC tires has ever lasted on my Vee, in the beginning about the ony thing I didn't like about them was less grip than I like on wet pavement
It turns out, that is not the most severe problem, I ride a lot of gravel roads, about 50% of my riding where they seem to excel in performance.... why do they excel, cause they clear their treads of debris very well, which leads to the problem, where the debris, pebbles, small stones, grit, etc, gets thrown
I hear more gravel hitting the underside of my front fender, yup, fender is now broken from the beating , mounting tab on the left side is cracked all the way across, only the mounting tab on the other side secures the fender to the fork
today I learn that I now have broken teeth on my front sprocket and my chain is toast, and the chain and sprockets (530) were installed same time as the tires just over 7000 miles ago when I normally get 45,000 miles from 530 chain and sprockets, only thing I can summize is that crap is getting thrown into the chain as well that other tires don't kick up that high
These tires are beating the crap out of my bike
Vendor
Broken teeth on your sprocket will ruin your chain and a damaged chain can brake teeth on a sprocket. It seems pretty likely that if your running 50/50 gravel roads that gravel is likely the culprit. A stone between the chain and sprocket will definitely do bad things.
Even if you believe the tires are the culprit I wouldn't stop with changing the tires though. If your going to run gravel that much you might want to add a sprocket and chain guards like used on dirt bikes. Some are plastic rings that go around the sprocket. Blackspire C4 Ring God Bash Guard > Components > Drivetrain > Bash Guards | Jenson USA
Longer chain guards are available that provide coverage almost all that way up to the swing arm pivot.
Seems like good insurance.
You could give the Shinko 804/805 a try? My buddy runs those E07 on his GS "of course it is a shaft drive" and says he will likely never buy different tires ever again because they work so well off and on road.
When I ran a K60 on the front I felt like I had the same issue. Rocks getting stuck in the tread and dragged through the fender. Fortunately I didn't break mine.
No such problems with the TKC80.
I have always ridden 40% or more gravel and never had this issue before, even running TKC80s and Karoo Ts
the guards on the link you posed only fit up to a 38 tooth sprocket
I will have to do some research
on another note, I just got back from visiting my bike at the dealer, my engine side cover (stator side)has corroded so much around one of the bolt holes that it leaks oil, $247.75 and on back order, eeek, I just scored one on Ebay used that includes the mounting bolts and stator for $21.24 free shipping
I'm not finding as good a deal on the front fender
" XV920Rs"
A classic design.
I think I've only seen one, in Oklahoma of all places, other than magazines.
a bike that was ahead of its time, one of the first mono shock bikes with what I would call "unibody" construction, a heavy pressed sheet steel backbone frame with the engine as a stressed member, The frame is also the airbox.
only sold in the US for 1½ years, in Europe a few more as a 1000cc up from 920, ergonomics and geometry very close to that of the V-strom and 505 lb weight, light for its time, the engine,easily modifiable to over 100hp, but under 70 in stock form.
a delightful 9"diameter headlamp that lights up the road at night as good as any modern high performance headlamp
I can't imagine the tire contributed to the sprocket/chain issue...I've run aggressive knobs on all sorts of bikes for years and years and run gravel like nobody's business and never seen anything like that on my bikes, including the Strom. Haven't damaged a fender, either, tho so there's that.
Discussion Starter #13
I have run many different agressive knobs as well, my riding style and maintenance regimen has not changed, brand of chain (OEM Suzuki 530 front, Sunstar 42t steel rear and ordinary DID o-ring chain) and sprockets have not changed
the ONLY difference is the deep chevron treads rather than block treads, I also notice/hear more gravel scraping on the underside of the front fender
and that is why I have come to the conclusion that it is the Mitas E- 07 Dakars, not that I was particularly happy with them to begin with, I was much happier with the now obsolete Metzeler Karoo T
however I may try the Mitas E-10 Dakars, they appear that they may be the most logical replacement for the Karoo Ts
Several big block tires in V-strom size are out there now, at one time it was just the TKC80 and the Karoo MCE and Karoo T,
Discussion Starter #14
I like this thread hijack so here is some more.
Yamaha was the first to race motocross with a mono shock, but they were far from the first to use it.
I know that there were mono shock bikes long before the XV920, the Virago also had the mono shock the first couple years but went back to dual shocks to compete better for sales in the cruiser market
in the UJM market, the mono shock was a novelty at the time
We talked about this on our ride today Craig, and Steve can see how this could happen with these tires. Of course he has high clearance fenders and a shaft drive on his GS. :wink2:
2wheelpros has the fender for $172 for the older stroms and $80 for the newer FYI, depending on which bike you have.
Discussion Starter #19
I can get a new one from my local dealer cheaper, with no shipping charges
So on the rear tire could you hear it throwing rocks? I just put one on the rear and rode a few miles of gravel roads, didn't hear anything.
1 - 20 of 34 Posts
