Dimming headlights is a symptom of low voltage in the system. The reason for that low voltage can be caused by a number of things, one of which is a failing battery. Mine used to do it from time to time due to corrosion on the terminals, which is why I mentioned that.I recall reading somewhere that dimming headlights is one of the first symptoms of a battery in bad health.
