That was certainly the case the last couple of times this exact question came up.You're never going to get agreement on this.
A couple........the search function is obviously broken.That was certainly the case the last couple of times this exact question came up.
I have also heard about using the kill switch unnecessarily wearing the contacts out prematurelyKill Switch Con:
Will leave your headlights on if your key is still on. Everybody looks at you funny when you try to start your bike and forgot to turn the kill switch back on.
that about sez it allIgnition Switch Pro:
Turns off everything
Ignition Switch Con:
None.
what does being on a hill have to do with turning the bike on and offKick Stand Pro:
Easy to park on a hill.
Kick Stand Con:
Hard to start on a hill. :biggrinjester:
I was thinking when you stop the bike, still in 1st gear, put down the kickstand to turn the bike off and now you don't have to worry about rolling backwards.Iwhat does being on a hill have to do with turning the bike on and off![]()
Perhaps, but it is easy enough to put it in neutral to start it - I do this every time.I was thinking when you stop the bike, still in 1st gear, put down the kickstand to turn the bike off and now you don't have to worry about rolling backwards.
When starting the bike you have to raise the kickstand and keep the bike from rolling backwards while you start it. (Suppose you could always put it into neutral)
Don't believe everything you hear (or read on the internet). By definition using the kill switch can't wear it out prematurely (even if it using it results in its failure), since it is designed to be used.I have also heard about using the kill switch unnecessarily wearing the contacts out prematurely
I have to say I believe what I heard even if it is parole evidence, it simply came from a trusted mechanic that's replaced 10times over more kill switches than he has ignition switches, and invaribly, kill switch failures occured on bikes that the kill switch was routinely used to turn the bike offDon't believe everything you hear (or read on the internet). By definition using the kill switch can't wear it out prematurely (even if it using it results in its failure), since it is designed to be used.
I'll second that opinion.my opinion is that kill switches are not built to the same duty cycle as ignition switches,
3rd here. While I don't have any proof that there is any excessive wear on the switch its self, I find it to be an unnecessary step when the side stand switch will do the same anyway. The side stand switch gets used every time you put the stand down anyway.I'll second that opinion.
