2014 DL650A
2014 DL650 with standard Kaoko throttle- lock, Oxford heated grips, and shorty levers. I will NOT give up my throttle-lock!
Which hand-guards are compatible?
I've tried OEM's and they just don't fit with the throttle-lock.
Don't really care if they are 'guards' or just deflectors. Just want to keep the wind and weather off my my hands.
Suggestions?
There is a version of the kaoko that can be used with the stock hand guards
OEM is absolutely compatible, but you need the correct Kaoko model. Hopefully you can still exchange yours.
2014 DL650A
Discussion Starter · #5 ·
Unfortunately, they came with the bike and are the standard model, so no exchange possible. I've since ordered the 'Powermadd Sentinel' guards which should suit my needs. Thanks y'all!
get one of these. Much smaller, works better, much cheaper. there are 3 or 4 versions so look at them closely and find the one that works best for your bike. I have one on my vstrom also.
2014 DL650A
Discussion Starter · #8 ·
Just installed the Powermadd Sentinels. Very easy and straight forward. I think I'm going to like them, especially being able to use the "knock-out" to get more air flow in summer.
