FYI, you need to jump the black/red wires and the black/white wires together on that connector. Without jumping those wires your 30A charging system is running on 14ga wires which is not rated for such loads. Suzuki wired (most) of the charging system with two 14ga (15A) wires instead of using a single 12ga (30A) wire. They probably did this to save money and to make it easier to wire up the harness (12ga wire is thicker and stiffer so harder to work with).
